I have found the only rear mount hydration that will work with an Adamo saddle is the cheap, $1.99 cage. You can use this and leverage it against the back of the seat and zip tie it to the rails underneath. I tried it with several other cages and they are all either too short, or not strong enough to zip tie it tight enough to hold. I put a load of black electrical tape where the cage meets the seat post to keep if from scratching the post. I also stuck a piece of velcro on the bottle and the inside of the cage just to guarantee im not launching water bottles. I also threw a co2 holder on the back side of the cage. System works perfectly… if you only need one bottle back there.
How does the bike hang on the transition rack? And it looks like your adamo is really tilted downword.
I hang it off the rack by the nose of the saddle… its not tilted forward to bad, might just be the camera angle.
Here’s my homemade bracket. Rode this morning and seemed to work out well. Just need to paint it know now.
Thanks for the photo. What did you make the bracket out of?
aluminum
