Everyone around here harps on buy the bike that “fits”. So what is that really mean? Noone can really define for me what a bike that fits is.
So I have been toying with something and it brings this into question. Here is what I came up with…
The black triange is my current stem on my current frame.
The purple is the change in stack and reach from Dan’s charts to go to a SMALLER frame.
The red is the resultant stem on the smaller frame that would position me in the exact same point in space relative to the bb.
I have a couple of thoughts on this…
the resultant stem is still within what I consider a good fit (<13cm)
the resultant stem is “easier” to come by
the smaller frame will move the steering axis farther back and the stem will have more leverage.
So, which stem/frame is a good “fit”? Are they both good fits? If not, which is the good fit and WHY?
g
It’s hard without knowing how tall you are and what size frame you are looking at. I.e., if you were 4’11" then I’d want a different max stem length than if you are 5’11".
Generally, I’d say that 13cm is a rather long stem for a tribike. Because of the additional up front weight on the aerobars, I tend to advise a stem that is ~2cm shorter than the equivalent “correct” stem for a roadbike. So if 13cm is the longest road bike stem YOU would want, then 11cm is closer to the longest tribike stem you’d want.
However, the stem length is also dictated by the specific aerobars you use (unless you are going aero or die) as some bars with excessively long pursuit positions can make handling very tricky. The newest Ritchey base bar is an example of this as is the “down-and-forward” sweeping Vision one piece. On an aero-or-die position, this is obviously not a factor, but stem length is still important in terms of your weight distribution relative to the front axle.
It’s also dependent on the frame itself. On a bike with a lot of trail and/or front center (Cannondale Slice) a longer stem is less problematic than on a bike with less trail and/or front center (Orbea Ordu).
So it’s a hard question to answer just based on what you’ve written. My default reaction is to fit first to reach and then fit to height. If a bike is long enough, there are many ways to change the height (different aerobars, stem pitch, etc.). But only one way to change the length. However, the question I believe you are asking is what defines “long enough” and that’s impossible for me to answer given only what you wrote above.
Uh, I believe that Greg’s questions were rhetorical in nature…
