Dr. Martin,
Regarding your paper looking at crank length and maximum power (http://www.ncbi.nlm.nih.gov/pubmed/11417428)I see one great weakness as it relates to triathletes. This study was not done with the athletes in an aerodynamic position.
What makes you believe that the subjects were any less “bent over” than any racing cyclist attempting to generate maximal power??
Well, the methods don’t specify the position of the riders. Second, if I watch the climbers at the TDF
So you think that the optimal position for extended climbs is the same as it is for sprinting?
What on earth are you talking about?
I’m talking about the fact that the study you cited measured maximal neuromuscular power during a test that last only a handful of seconds.
Anyhow, it would be nice to have a study that specifically addressed this issue
Why would a triathlete care about the effect of crank length on their maximal neuromuscular power?
You didn’t really ask this question did you?
Indeed, I did.
Let me ask you? Why does a cyclist care about it?
Um, because breaking away from a pack usually requires a rapid accleration, and many bike races end in bunch sprints?
Yes, but even breaking away doesn’t require maximal neuromuscular power (it simply requires a sustainable increase in power) and only a few are going at maximum neurological power at the end of a bunch sprint. That study only has usefulness to most athletes from what can be inferred from it about other types of riding/racing.
Why did Martin do that study
You do know that Jim was a national champion match sprinter, don’t you?
So, why did he do the study?
and why did you reference it here if no one cares?
I didn’t reference it: you did.
No, you first referenced it here, many moons ago. Why reference it at a triathlon forum if you believe it has no applicability to triathletes?
Anyhow, to answer your question, a study has to look at something and maximal power is a good, fairly reliable, end point.
True, but if you are interested in sustainable power, there are better things to measure (and have been measured. That’s why your criticism/questions are so far off-base.
But, he didn’t measure those other things. We have to work with what we have. One can make reasonable inferences from this data. So, give us a reference to a better study if it is out there that relates to this issue.
if a researcher wanted to look at another aspect of power and how it relates to position and crank length, that is fine with me. I would simply like to see some work done on the subject, wouldn’t you?
Sure, and in fact when Jim’s student John McDaniel was planning his dissertation I lobbied for measuring submaximal performance as well as efficiency. I am at a loss to explain, however, why you think that another study focussed on a different question suffers from a “great weakness” simply because it addressed an entirely different question than you thought it should.
Well, I think position affects this stuff. A study that doesn’t control for position has a weakness in my opinion. I simply think that a study or two that looks at how position and crank length affects sustainable power would be a wonderful thing for the bike fitter (trying to fit a triathlete and the cyclists who care about this stuff) or athlete who “fits” themselves. If one can’t study sustainable power and efficiency and all those good things then a “simpler study” looking at the effects on maximal power would be a good start, imho.
