A poll: Maximum power numbers (efficiency and sustained)
OK, put your reputation on the line.
  1. What do you think is the theoretical maximum pedaling efficiency the human can obtain based upon watts to the wheel vs watts consumed? This number should be one that you would be embarrased if someone ever exceeded it but one you think is achievable in the next century without drugs?
  2. What do you think is the theoretical maximum sustainable for 5 minutes watts per kg obtainable by the human cyclist based upon watts to the wheel vs rider weight? This number should be one that you would be embarrased if someone ever exceeded it but one you think is achievable in the next century without drugs?
Hey Frank, your poll just asks about cycling numbers achieved by any means and as such could be non PC related (likely are). You would have much more credibility if you just titled this thread: Maximum power numbers (efficiency and sustained) by a human and left PC out of the title. People are already bent out of shape about PC related infomercials. Since your poll has nothing to do with PC’s you could have left it out of the title, mainly to gain credibility amongst those who are anti PC…and you know that as a PC owner, I am supportive of your product, but the guys may have a point when you insert PC’s into every posting :-). whaddaya say ?
Dev, done. But, it won’t make any difference. Whatever I post I am attacked by some of these people. Time to put a reputation or two (albeit “annonymous” ones) on the line. Most of these debates have nothing to do with the PC’s anyhow, they just think it does. These people cannot think of possibilities, however achieved.
You got an answer from your primary nemesis. Now tell us some numbers achieved by PC users. I can’t help but imagine that when you were posting your initial message you were looking at some data from riders of your product.
Frank, your question about Input/Output is very interesting. I have no clue how many joules per second of stored energy my body consumes to delivery let’s say 250 W to the pavement. I would suspect that chemincal inefficiencies in the human body (converting potential energy to kinetic energy), mechanical inefficiencies (friction in joints and within the strands of the muscles etc) gotta be huge. I would say that the body likely uses up something in the order for 1000 Joules per second to put 250W into the back wheel, based on few mechanical/thermodynamic systems) like the carnot cycle not having huge efficiency (numbers like 70% pop up in my head from 3rd year engineering almost 20 years ago). I doubt that the body is any more than 25% efficient.
Looking at it another way, if top Ironman dudes are consuming 500 cals per hour (which is actually 500,000cals per hour), then that would be 500,000x4.18/3600 joules per secod = 580 joules per second of food consumption. Given that they using more energy than they are eating, (perhaps, in the order of 800 joules per second), and let’s say delivering 200-250 W to their back wheel, then 25-35% efficiency might make sense ?
By the way, thanks for changing the title. Now we can have a reasonable discussion.
  1. Delta efficiency of 32%.
  2. 8 W/kg.
  3. The two will not occur together.
I believe I asked for gross efficiency. How about that number?
my understanding is that, generally, delta efficiency is a much more useful measurement than gross efficiency
Don’t have a clue about the theoretical max, but here’s some of my own ‘results’ that are probably about as reliable as those you get from folks sending you e-mails…
Note: I am cheap, so my power results were from a Polar power meter but my setup data is correct.
30 minute trainer (2-1/4 inch rollers) ride:
Calories Consumed: According to Polar’s formula - 556 kcal
Work: 651 kjoules
Efficiency: just under 28%
Either…
a) The Polar power meter overestimated my power (360+ watts)
b) The Polar algorithm underestimated my calorie burn.
c) I am superhuman.
d) All of the above.
If I had been training on PC’s, the correct answer would be (c) and I would have already e-mailed my results to Frank for him to ‘publish’ in one of his ‘letters to the editor’ or something. Since I haven’t, I’m going with some combination of (a) & (b).
cool, he can give a GE number also.
how about 250W ?
Dev,
this ain’t so easy to answer. I was taught in medical school that the energy conversion efficiency of contracting muscle is about 50%, even though this is not easily explainable. I have been able to find a couple of references that support this:
www.ncbi.nlm.nih.gov/entrez/query.fcgi?cmd=Retrieve& db=PubMed&list_uids=1836543&dopt=Abstract
agave.esfm.ipn.mx/moyo/papers/muscle1.pdf
The efficiency will vary a lot on muscle type, the force of contraction and the speed of contraction, etc. But, however you slice it the efficiency of well rested muscle contracting aerobically probably never gets below 40% in endurance sports athletes.
However, measures of gross efficiency of cyclists are all over the place but are rarely above 23%, mostly ranging from 15-23%. This is about half to less than half of the contracting muscle efficiency. Where is it lost and can any of these losses be avoided. Some is lost in the chain and bearings of the bicycle but these are quite small. Some is lost in the need to keep the body alive with resting metabolism of all the other organs, which is pretty constant but cannot be modified much. Where are the other losses? That is what this question is really about.
The muscle is not a carnot cycle or any other kind of mechanical device for doing work. However, the body as a whole (and the body bike system) and the muscle must follow the laws of thermodynamics. It is a simple matter of analyzing the losses and seeing if there is any potential room for improvement. Obviously I think there is.
I can assure you the top IM dudes are not converting energy into work now at a 25-35% rate. Probably more like 20-22%. But, what is the potential? If we know that then we know how much room there is for improvement, even in them.
We can’t until you specify a power.
  1. Most efficient power.
  2. Max power sustainable for 5 minutes.
Finally, something we can agree upon completely.
You’ve got it backwards- maximal muscle efficiency is around 40%:
http://www.ncbi.nlm.nih.gov/entrez/query.fcgi?cmd=Retrieve&db=pubmed&dopt=Abstract&list_uids=15501465
Whatever, put that into your answer.
You still haven’t specified the conditions sufficiently for us to answer.
sure I have as you can specify the conditions that you think will lead to the biggest number.
Read this, and you might begin to understand (but we doubt it):
http://www.me.utexas.edu/~neptune/Papers/essr30(4).pdf
That is an interesting paper. I did a simlar analysis of all the principles they mention that leads me to conclusions that are quite different than theirs. Perhaps if they had done a thermodynamic analysis we might be in better agreement on some items. Too bad they have to make so many assumptions in it in order to come to the conclusions they wanted to come to when they started. If all of their assumptions are correct then it is a great paper. That is a very big if.
Oh, we just got another pro on them. Currently ranked UCI top 100. too bad he doesn’t understand this paper so he wouldn’t have to waste his time.
My answers to the original questions:
1 - I don’t care.
2 - I don’t care.
Train consistently, train hard, do it over a peroid of years and you will improve. People are way to wrapped up in numbers, heartrates and the latest gadget. Put in the mileage and be intelligent about it.
For me, looking at numbers just takes the fun out of it - I already have one job and that’s enough.
Oh yeah, Frank, I know you love your product but it’s just getting stupid now. I know, you only mention them when you feel it’s appropriate, but enough already. Give it a rest for a little while.
Let’s see. So far this thread is 25 posts long. The Committee has had the cajones to give the number 29.5% for the first question, I presume as it wasn’t specified.
Thank you. Actually that isn’t far from what I would predict. I would guess that about 30% will be routinely achievable in 10 years with a theoretical maximum of maybe as high as 33-35%.
Now, the question I might ask the Committee is what would he do to help the rider come closer to this number (assuming he believes there is a benefit to being more efficient)? The rest of you with no balls can butt out. Where are the inefficiencies he sees that are correctable? (I presume he believes that most riders now are at efficiencies well below this number now.)
BTW, the more I read that paper The Committee referenced the bigger pile of crap I think it is. They are presenting a hypothesis and nothing more in this paper. Their analysis is extremely flawed. We can start with their analysis of Figure 2.
With the second coming of the Christ Consciousness in the next 100 years, transmitted through the vessel of an African Lesbian, I believe we will see 100% efficiency by Her. Sport will finally have been transcended.
Frank, let’s put it another way.
What do you think the ratio is with respect to input joules vs output joules with respect to in the top notch world class marathoner over the course of a race. Since we have evolved over many thousands of years to run, I would suspect that this would represent a nice target for what could be theoretically achived in cycling over an equivalent period, given that humans are not optimized to ride bikes, but are built pretty effectively to run. That should represent the top end of your efficiency question. For the 5 min duration, take the miler vs the 4000 m pursuit guy. I suppose the output joules produced are fairly easy to measure, but how on earth do you measure input joules, since they come from stored potential energy and in a longer event are topped up with food that may or may not be digested (and as you pointed out, digestion and other normal human metabolic functions use up some of these joules)
In any event, my back of the envelope 25% does not seem to far off the pundits. This whole thing is a nice academic exercise, but as one poster pointed out, if we do the training, good things will happen :-).
On that note, I have a 2:45 sub 20% efficiency long run to get ready for Boston tomorrow morning. It must be an “off day today”…I have too much energy to make useless posts !
