I have always raced on Conti Comp GPs - 19 in front, and 22 in back. I am sure tempted by the Tufos with the red tread but only because I think tghey would look good. Any thoughts on the best tires for the 999s? Josh?
Thanks!
Thanks!
Tufo Elite Jet, <160g, 700x20. Or the S3 Lite.
“I am sure tempted by the Tufos with the red tread but only because I think tghey would look good.”
I just received a set of 909’s and went with the Tufo S3 Lites all black. I have the exact oposite feeling towards the red ones. I took off all the stickers and the 909’s look lighting fast in all black. And that’s what it’s all about, “Looking Fast”
Tufo Elite Jet <160.
These tires have no equal
If you wanted a bit wider, I’d go S3 lite <215 or HiCC <215.
A bit narrower and the <195s will work.
Even the <215s and <195s are a significant improvement over the Conti GPs.
Enjoy your new wheels, great choice there!
-SD
Tufo Jet Elite. 160g. How are you gonna argue with that?
Both the disc and 808/999 front wheel were designed around 21mm tires idealy, so you will find that both of these wheels work better aerodynamically with 21’s than anything else. Having said that, a 19mm or 22mm tire will be very good on either as well, but you are giving up a little bit of aerodynamic performance, albeit very small. We first developed the Zipp tire around our disc wheel and it has continually proven to be the fastest available for use with that wheel. We have not seen as large an advantage when using the Zipp tire with the 808 or 404 depth rims when compared to something like a Vittoria CX or Evo series tire, but it does seem to offer slight statistical advantage at most every wind angle, but the advantage is small. Mainly the Zipp tire has a specially designed tread that is completely flush with the casing, so there is no tread lip which can be a major cause of flow separation on the trailing edge of a disc wheel (similar effect occurs on V shaped rims). The shape of the 808 or 404 helps to add an circulation component to the flow as it moves over the curvature of the sidewall which minimizes the negative effect of the tread lip (although the effect is still present), which is why the Zipp tire is still advantageous on those wheels, but slightly less so than on the disc.
So I guess if you want the tire which was designed for the wheelset, get the Zipp tire (which also happens to be an incredibly nice handmade tire with 300tpi casing and killer looking all black construction (including base tape) http://www.zipp.com/products/acc/tires.shtml) or the next most similar tire would be a Vittoria Evo KS followed by the Vittoria CX/KX or Tufo S3 lite. The Continental Competition22 also works well, but I would avoid the 19 as you are giving up both aerodynamics and rolling resistance over the 22mm when used with our rims, the 19’s will be necessary with most V shaped rim designs so that the tire is narrower than the rim, but on our designs, a 19 is most always slower (in the wind tunnel at least).
I hope that helps a bit and doesn’t seem too much like a shameless ploy to sell Zipp tires. The reality is that the tire was developed around the wheels (2 years ago), and the new wheels are developed using that tire, so that it almost always turns out to be the fastest option.
josh
And the Tufo folks are great with support. I e-mailed them a question yesterday about the sealant and received a reply in one hour from some dude with a Chezk name (ok I can’t spell the darn country). Very helpful. By the way he tells me the sealant lasts a few months before it solidifies so put it in right before your big race.
Mike
