9 swimming-races in one weekend!
So this is my problem, we have this meet (Danish team championships) with my swimteam in 9 weeks - and I totally trust my coach, so I don’t need advice on training and taper.! I need some ideas for fast recovery between the races, since I’m one of the fastest boys I have full program which means 5 individual starts and 4 relays, in 2 days. Active recovery between the races is not an option, the only chances I have for swimming becides my races, is in the morning, middle of the day where we have a 3 hours lunch break, and in the afternoon after the last races. What should I do, eat and so on to be better prepared.? Last year I really sucked at the last 2 races sunday…!
Schmidt-DK
Protein recovery shakes and gummy bears.
Protein shake after each race?
  1. Keep warm. Don’t let your muscles get cool.
  2. Don’t sit in one place for too long before the race. Lots of nice gentle, very low key movement and stretching.
3.Do lots of cheering for your teammates. Helps you get into a mentally good place for your own races.
Isn’t that a pretty normal meet schedule? It was for me when I swam AG and university.
You mentioned 5 individual starts - are these “straight to finals” or are you just talking heats?
A lack of a decent warmup & warmdown facility is not uncommon at many meets, but if you are talking about a championships meet, it is a bit surprising. In Canada, provincials and nationals were usually held where there were 2 pools. In some cases it might be the diving well, but at least it is something.
Anyway, some hints.
snack throughout the day.
Figure out which races you have the best shot at winning / making finals, etc. Swimming is about PB’s, sure, but it is also about racing and figuring out which races you are best at. After a while, it isn;t about PB’s at all. It is just about racing.
Stay hydrated.
have a nap during lunch break, if you can. (especially on day 2).
milk the time between heats, if possible. what I mean is that if they will let you get away with swimming half a length after your race, just slowly, an then getting ou on the side of the pool, then do it. Depends on how the meet is run.
Don’t sit around, especially before or just after a race. Do arm circles, light stretch cords, or something just to keep loose.
Have a good sleep between days.
You are stronger this year than last. If there are events where you are “guaranteed” to make finals, you may want to hold back a little on those during heats.
I would go with one shake after day one. Between events, try to rest without ever getting cold. Spin your arms a little. Take a “power-nap” on the lunch break. The gummy bears will be in your pocket and every once in a while, you throw a few in
If there is not a separate warmup or warmdown pool, then you can try a hot shower before and after races to loosen up. Also, move around for a little while after races so you don’t tighten up. If you eat more or less normally, you should be fine as you shouldn’t be burning up too many calories in your races.
That’s a pretty typical schedule for a championship meet so the first step is to relax. That’s just how swimming works. Actually, unless you are swimming distance races or your races are only a few minutes apart, recovery won’t be an issue. The bigger issue is just getting through the weekend without expending any unnecessary energy.
The tips above are good. I’ll add this. You’re going to have alot of energy because you’ll be tapered but every minute you are not in the pool should be focused on not wasting any of that energy. For example, don’t be a hero and carry your own bags if the hotel has a bellman. Make your coach drop you off and pick you up at the door rather than walking from the parking lot. Get to bed early. Keep off your feet as much as you can. Standing up for 4 hours is going to tire you out more than swimming a race.
I assume you are not in this position or you won’t be asking this question :wink: but if it is a prelims/finals meet and you can make the finals without going 100% in the morning swim back it down a notch in the prelims.
One other thing. Stay warm. I assume that winter in Denmark can be quite cold, and the pool deck might be cool as well. If you have a hooded parka or a polar fleece, wear that on deck. Wear a touque. (within reason of course, you shouldn’t be HOT. but you don’t want to be wasting your energy trying to stay warm. Let your clothes do that for you.
