650cc or 700cc
What is the deciding factor for riding a 650 or 700 wheel bike?
650cc or 700cc <<
The 700cc has more displacement, so unless you make up for it with either a turbo- or a supercharger, it’ll be faster.
LOL, very funny Wheinle
650c or 700c usually is determined by frame geometry. Nowadays you will mostly find 650 wheels on smaller frames. Some will tell you that you can get into a more aero position with 650’s rather that 700’s but I am no expert and I’ll let them chime in.
The claim was that 650’s were faster because they were more aero due to the small size. True, but it also meant that frames had to be built with a longer head tube which negated that aero fact.
650’s have their place which IMO is on smaller frame bikes. For medium size riders they can ride either size, but 650’s seem to be falling out of fashion. I never understood why some bigger frame tri bikes used 650’s in the first place. They looked like circus bikes. Just bring along the bear and the clown.
Something along the lines of:
For Tri geometry:
Under 5’ 6" - 650
5’6" - 5’10" - either
Over 5’10" - 700
For Road geometry - 700
I’m 5’ 10" have been racing on 650 ever since I got into the sport, because someone told me 650 was “faster”. We’ll I finally upgraded my TT bike to a 700 this year, and I will NEVER EVER go back to 650. There is just so much less rolling resistance with the 700, I’m using a lot less effort to maintain the speeds I achieved on the 650. Do you ever see 650s at the TDF???
Hey Foo…don’t forget two things…
  1. The fastest IM bike times were still done on 650 wheeled bikes
  2. The Tour de France had never seen an aerobar until some guy named Greg LeMond brought it into the mix. People may argue with me, but cycling is so set in their way and they use certain equipment not because it is based on science but rather based on tradition. Think about it, 700c wheels have been around since the dark ages of cycling. Please tell me how they came up with the 700c size. They certainly did not have the tools to test for the best sized wheel. I would not look to the cycling community for proof of anything (other than their knowledge on how to train).
Can’t remember the details but they did try 650’s at the TDF with one or more of the top teams/climbers one year. They went back to 700.
There seems to be advantages/disadvantages to both that balance out.
AJ - you’re right about Hawaii, that’s one of the reason’s I continued to use 650s on my race bike the past couple seasons. However, just from I’ve seen early on, I am riding much faster on my 700. I know 2 guys last year who switched from 650 to 700 and they were clearly faster cyclists, their times were at least 1 mph faster than prior years. I bet Hellreigel and Zach would have done just fine on 700s - I’m not sure what Larsen uses?
I would say the one advantage to 650s is on climbing steep hills, it just seems like I have to work so much harder with the 650 on flats - and I even used a 56 - 21/11 setup.
As far the Tour goes, well they finally switched over to aerobars because research showed they were clearly faster - I’m not so sure research says the same about 650s.
If 650s work for someone - great, I guess my comment would be for someone to try both and just see which one they prefer.
I’ve been on 650s for a long time. There isn’t a huge advantage to them, but they come with some significant and obvious disadvantages, which is why you see them declining in popularity. The disadvantages are tire selection and comfort. I doubt there is as much difference in rolling resistance as what you are feeling. The advantages are the wheels are lighter and/or stronger, and more aero. But again, the difference is not so much that you can measure it with a watch on a course. Probably the best reason to go 650 is if it helps with the frame geometry for you, otherwise it is less hassle to go 700 unless you are in an event where a few seconds makes a big difference, and in that case you probably know more than me. Whichever way you go, you will tend to stick with it due to an investment in wheels. This has been hashed about several times if you check the archives.
Ditto what Dan said. I have been on 650’s since starting the sport 7 years ago. Had no real biking experience previous. I think the difference in rolling resistance and or aero between 650/700 is marketing versus science.
However your limited wheel and tire selection on 650’s is real. I hate paying almost 40% more for tires and having a limited selection in 650.
In summary, if the frame you are looking for is available in 700 and fits go with 700.
Peace,
RF
