Hi All,
this is my first posting to the forum. I inherited a Hooker Elite Cat 1 road bike and a bunch of cool hooker stuff along with it, including a 650c fork with an 18 hole 60mm over-lock-nut hub that accompanies the fork. I’d like to build the hub into a 650c wheel and install it along with the 650c fork on the road bike. Can anybody with experience or knowledge on this conversion advise me as to whether or not this is a dumb idea? I don’t know the rake of either the 700c fork that’s currently installed, or of the 650 that I’d like to replace it with. I’m concerned with the effect that this change in geometry will have on the bike’s rideability.
Hi All,
I’ll probably just be doing local 20k TTs.
Thanks in advance,
Charlie
Charlie,
Probably a no go unless you can make a crown race that is ~50mm tall for the headset used on the 650c fork.
Along with your too-low BB and exceptionally steep head angle you’d likely be better off (aero and handling wise) on a modern fast 700c wheel than that old 650c relic.
-SD
Hi All,
Thanks in advance,
Charlie
I and many other Hooker riders (e.g., Kent Bostick) did precisely what you’re suggesting back in the 1990s. While the head tube angle increases by a degree or two (I worked it out at the time, but don’t recall the exact figure), the lesser rake of the 650C fork keeps the trail well within the normal range, such the bike will handle just fine. You also don’t really have to worry about the b.b. height, as it is very high w/ the 700C front wheel (befitting the bike’s S. California/crit-centric/track-centric heritage) and simply drops to normal w/ the 650C front wheel.
-SD
I hate to say it Dave, but I think you’re 0 for 4 in that sentence above…I’m with Doc C. I think he should race the snot out of it
Hi All,
Thanks in advance,
Charlie
Did you happen to get the “aero or die” TT bars with it?
BTW, if you decide you don’t want to bother with it, let me know and I’ll make you an offer…I’m still kicking myself for not buying Andy’s a few years back
-SD
You are totally wrecking my chance to swap him for a new B2 frame and help relieve him of that “problem”
-SD
Shaun Wallace rode a Kestrel I made for him to a silver medal in the pro pursuit worlds in 1991.
I calculated (at the time, now I’m going from memory) that the fork and wheel change lowered the front of the bike about 4" and the BB about 40% of that.
All the frame angles increased by about 4 degrees. Head tube was 74, now 78 degrees; roughly the same with the seat tube: was 74 (or 73.5?), became 78 (or 77.5?).
The lower frame stack was good for a pursuit position with aero bars. The down-sloping top tube looked bitchin’.The steeper seat angle matched what tri guys were doing: rider forward.The lower BB was bad, but Shaun decided it would be okay on the track if he was careful.The steeper head tube angle (even with the decreased rake of the 650C fork) made steering really quick. But Shaun said he liked it.
I’d expect similar changes on your Hooker. (Only, the lower BB will be an improvement on that bike.) So consider it, but know the downsides and make your own decision.
Hi All and thanks for these replies. The preponderance of opinion is to give it a whirl so I installed the fork and am having my shop build up the hub on an old 18h HED deep carbon rim. I’ll post some pics when I get the wheel back this weekend.
