okay, I understand I could get a few lectures, but thought I might ask anyways…
my last fit was on a speed concept 9.9, size large. It fit me pretty well, with one small spacer in the aero bars. I am a hair over 6’, with avg ratio of lower/upper body.
I was looking earlier at some guidelines going off of your height for the p3 sizing, and that said I should get a 58. Was trying to do some searching here in the forum, but am more confused with some of the threads I found.
If anyone might have some experience with this, or advice, I would appreciate it.
The Speed Concept and Cervelo P3 fit very, Very, VERY differently. The Cervelo, as already mentioned, is long and low. The Trek SC is more tall and narrow.
I understand that. I actually thought I could have ridden a larger speed concept, and also ridden it lower.
I had also ridden a cannondale slice 56, and did not like it much. Seemed too short a cockpit, think 58 would have been more comfortable. I could not get stretched out on that one.
If you posted your fit measurements it would help.
I am about the same height, leg length as you. The 56 fit me perfectly. I rode it with no spacers and 16cm of drop. If I wanted to ride with less drop I would get the P2C. Start at the front of the bike and work backwards.
