I am right on the edge IMO on the 48cm and 50cm Aegis Victory and was wondering if anyone out there has either one. If so what is your saddle height set too? What is your height? What is your leg length? I currently ride a Bianchi FG Lite 49cm with a 90mm stem. The top tubes seem short compared to a lot of other road bikes out there as I have always run a 51.5 - 52.5 top tube length depending on what manufacturer and always a 90mm stem and usually Salsa Poco bars or other types of short and shallow drop bars. I am 5’4" and run just about a 30" inseam. Any feed back would be great and if you have photos of your set up that would help too.
I’ve got a 52cm Victory, if that helps at all.
Do yo have any photos? Also, what is your seat height, how tall are you, etc?
Seat is about 69 cm above the center of the BB. Straight Thompson seatpost, as you can see. I’m just a little above 5’6", with a 31" inseam (compressed).
I took this photo last year, and have since lowered the handlebars by 1cm. This leaves me with one 5mm spacer between stem and headset. I find the whole setup pretty comfy, and tend to ride primarily in the drops.
