50/36 vs. 50/34
I have a chance to get my greedy little hands on a set of the new 50/36 Bontrager compact carbon cranks and I was wondering the pros and cons of 36 vs. 34.
I suppose Bontrager went with the 36 inner ring to keep the tooth difference at 14 like 53/39. So there should be no issues when shifting between the front rings?
Also, it seems to me that 36 might also have the advantage of allowing us to use our 11-23’s instead of having to swap for 11-21 which many folks seem to be doing.
Your thoughts?
Mike
You should check the capacity of your front derailleur. The bigger difference in the front, the less gear overlap you’ll end up with.
My Stronglight compacts came 50/36 which I changed to the rear to a 34. Can’t say I noticed a lot of difference.
So what kind of gearing do you typically run on the back then?
Not a huge difference between the two, but enough to matter. I live in a pretty hilly area - there’s really not much in the way of flat rides. We also have mountains - 5 canyons within 20 miles of my doorstep, ranging from average 5% to 9% grades. I’m telling you this so that my gearing choice will make sense. I use a 50/34 and an 11/25 (you have to buy two cassettes and mix them up). This is awesome for me. I can do all of my long rides, even the hillier ones, in the 50 chainring. The easier canyons I can do in the 50 as well, but the steep ones, especially in races, I tend to bottom out so I can spin like crazy.
"So what kind of gearing do you typically run on the back then? "
11-23 or 12-25
I run 50/34 with a 12-25 10spd cassette. I can spin out the 50x12 when I’m coming down a big hill or have a wicked-hard tailwind, but that’s about it. If I get really strong over the winter I can see possibly going 11-23, but really the whole reason I got compacts is because I suck. :wink:
You don’t need compact cranks to go with a 50/36. Stronglight makes both 50 & 36 in 130 BCD
"Stronglight makes both 50 & 36 in 130 BCD "
Available online from xxcycle
http://www.xxcycle.com/cgi-bin/shop.pl?SCREEN=lp&MARQUE=0&SEARCH=&CAT=7&GO.x=6&GO.y=11
Where’d you find 130 BCD 36 rings? I have been told by damn near everyone that 38 is the smallest that are out there. I can’t even find them on their website. Do you have a link?
I think you’re right. 38 is the smallest for 130. My wife has 50/38 on her dura-ace cranks.
