I’m Looking at the 3T Brezza, but can’t find info on adjustability options. I’m particularily concerned with the distance between bar centre and pad top as I need it to be as close as possible to get low enough. I ride Visions now and do not want to be higher at all.
Anyone have any experience with these bars?
5cm. MUCH taller than visions. If you want lower, you’ll need the 3T Mistral. Or the Easton. Or the PRO. Or the HED.
Wow, that is tall. I can get a wicked deal through our team…but if the fits wrong it’s wrong.
Any recommendation between the Easton, Pro or HED?
HED is the most adjustable by a long shot. It also has way better pads. I think the new HED corsair is the nicest in terms of positioning, and that’s what I’d get if I needed a really low-stack bar.
That HED is impressive - but without the team deal out of my range.
Would it be possible to use different clips on a Brezza?
The Mistral: does it come in 40cm width? Can I swap out for other extensions (ie: carbon) and swap out for Ventus pads? And can the upturns on the base bar be removed? And, can the extensions be placed above the bar instead of under like in the pics? 3T’s site is pretty lousy for information.
Any other suggestions? Thanks a lot
The Brezza is not going to work for you. I mean, I guess in theory you do like the Garmin boys and machine done the clips and then buy new screws for it, but you could also then end up with something that still doesn’t work.
I don’t know on Mistral width. But really, width shouldn’t be a limiter. It’s not that important a position.
Yes, the bars can be mounted above the basebar - see the pic on the P4 on the 3T website.
No, the upturns cannot be removed. Well, I am sure they can, but you’d have to be quite handy.
If you are on a budget, stick with Vision. It’s really the best bar for the price.
