First sorry for the long post but I wanted to get as much detail as possible so you don’t have the same headaches. I did try to route it like the instructions and it didn’t work.
Let me explain why I think the instructions don’t work. If you follow the instructions, you would have had to cut the main brake cable about 1-2 feet long and would have ended it right where the controller was. You would have then had to buy a long brake cable for the third aero bar brake and routed that one through the controller to the rear brake pads. If you do it this way, the third aero brake has the most braking power and the rear brake (original brake) has the lower braking power. The original rear brake becomes the speed bleeder. So, if you route it like the insttructions, your aerobrake will be very powerful and your original main brake is weak. If you route it like the instructions, main brake is a 6 or 7, the aerobrake is a 9 (didn’t give it a 10 because it’s so small).
Side note…if you follow the picture, you might get sticky cables, as where their controller is, it is as if it sits nicely under the aerobar extention. It looks clean, but with all the bending of the main brake cable as in the instructions (which is the shorter cable) , it creates a “sticky” brake situation because the cables are more in a bending loop than a straight line.
So, learning it the hard way, I did as the instructions said, and messed up everything. I had to go through several packets of cable housing and cabling and reinstall everything the other way. So, ultimately, the original rear brake cable is the long one. It routes all the way back to the rear brake pads. The 1-2 footer long cable, the one for the third aerobrake, ends at the controller as in the picture. Routing it the way I have it (not like the instructions), the original rear brake is as powerful as if the aerobrake was not there. The aerobrake has about a 1:3 ratio braking power with the way I routed it. So, routing it my way, the main brake is a 10, aerobrake is a 6.
Also on a side note, I put the controller right where the main brake cable exits the aerobar (which is by the stem). If you twist it like they want in the original picture, your brakes get a little sticky because of the wide looping turn. At least for me.
The tube is a cateye light, infront of a cateye astrale 8. I used to put the light and computer on the main bar next to the stem but it doesn’t fit well. This cateye model allows you to twist or mount it anyway you want, you can even put it on your helmet.
I love my dual. It’s the only bike I have, hence all the lights and other gear…people say it’s one of the best bang for your buck bikes. Can’t wait to see a pic of yours.
Hope I answered your questions. PM or reply to this post if you have problems. Hopefully then you won’t have to go through so many problems.
