35 min in the gym?
This winter I will be able to go to the gym at work in my worktime two to three times a week. But I only have something like 30-35 min (I will warm up with 15 min running first).
I have not been in a gym in 20 years and I have two questions.
  1. What exercises should I do?
  2. Will this help me get better in triathlon and running? Or should I just run instead?
Tribent,
For your tri-needs, you’d probably get a lot more out of the time by running/cycling than by lifting weights.
If you’re dead set on hitting the weights, you might see if you get something useful out of doing a routine consisting of swings, snatches, and clean & jerk with dumbells(sp?) possibly mixing in some jump rope in between. Take a look at the ‘kettlebell’ stuff on dragondoor.com. I have the first video and it’s excellent. MikeMahler.com also has a booklet guide filled with useful excercises. You can just substitute a dumbell for the kettlebell.
Enjoy.
  1. Squats, great all over exercise that wil help your legs.
  2. lat pull downs, nice long smooth pulls to help your swimming.
  3. low rows, good for your stroke and lower back to help when your on the bike.
  4. pull ups, one set with your palms facing you, one set with palms facing away, and one set with each palm facing a different way, like how you’d grab a baseball bat. Then stand under the bar and try to pull your chest up to the bar, you have to arch your back a little on this one.
Check out this link http://www.trinewbies.com/weight1.htm from trinewbies.com. I’ve ben using it for awhile now during the tri season during my 30 min. lunch break at work. If you do 1 set of 12 reps all the way through, you’ll be able to easily get it in in 30 min. this includes changing clothes twice and a shower. I personally think 15 min. of running to warm up is too much. I assume you’re going to have run workouts away from work, or at work on different days, so start your weight sessions with some stretching or yoga.
It works. Just last night as I was leaving the gym, a woman, also working out, whom I know but rarely speak with says “you’re getting buff!” I thanked her for the compliment and smiled the rest of the day. :slight_smile:
depends on your fitness level, but without knowing:::
run
run
run
run
run
run
sv-
Contrary to what some might say, 35minutes is enough. 45minutes is the maximum anyone should be in the gym working weights. Any longer and cortisol levels rise, testosterone levels drop, due to the workout stress. Under 45minutes is the optimum else the increased cortisol will breakdown muscle from non-worked muscles. Get in there, do the appropriate weights, and get the heck out. Posing or socialising in the gym is wasted time.
  1. The TNO workout already mentioned is a good place to start. customerjon, despite his strange beliefs about running, also has a good set in his post.
  2. Weights may well help with swimming and biking. I personally think the only part weights have to play in a pure running training program, is as part of injury prevention/recovery. I don’t think weights will help you run faster. But they are good insurance against injury if done right.
Doug, I found my running most improved by weight lifting. I was a lot less fatigued in my upper body - shoulders/neck/arms/back when I am lifting.
Many runners incorporate light resistance training into their programs.
Not sure if anyone mentioned this, but core training is also important. Gordo Byrn has good section on it at www.byrn.org
Craig
Also check out this link for reasons why runners should lift weights. http://www.runnersworld.com/home/0,1300,2-78-81-576,00.html
