3:30-3:45 IM Run split ... How?
maybe someone mentioned it and i missed it but i think that so much of running well in an ironman is mental. everything
is telling you to stop, slow down or just walk a little but if you can just shut your head up and keep moving along…
admittedly i only ran a 3:49 in placid last year but it was a breakthrough for me to silence the negative thoughts and just keep running. i went to the bathroom at mile 23 but by just running i passed literally hundreds of people.
You can’t will yourself to perform at a level you haven’t trained to. Miracles don’t happen on race day.
Run fitness is key, but without bike fitness, forget about it. I know a guy who is 2:30 in the marathon and ran a 2:05ish in his first Half-Ironman.
The key for me was not walking at all. Even when it got hard. I also had the strategy at CdA to work hard up the hills, go easy down the hills, and settle into an easy pace on the flats. Sure, there weren’t that many hills, but it was enough. And this is only my 5th marathon (only ever run in triathlons, and this was my 5th Ironman). I think marathons are crazy.
And Dev-it was the chocolate chip cookies that got me through those last 10 miles. Cookies and water, that’s all I grabbed. Thank you Chips Ahoy.
I’m willing to admit I may have just pulled a great race out of my ass, but that’s what worked. And cdarun, I managed to have a decent bike split, which is what set up my run and my placing. My run, going into Kona, is still a huge achilles heal.
At the end of the day, it boils down to doing more. More hard biking, more running, more bricks, longer bricks. But now that it’s over, I can’t stop eating. Anyone know how to fix that?
  • You can’t will yourself to perform at a level you haven’t trained to*
you just ruined my entire season.
I’ve done 2 IM mary’s (last season) 3:24 at IMLP, 3:29 at Kona. Here’s my take:
– how often are you taking nutrition/water in the aid stations? every mile? every other mile? every 3rd mile?
Water at every aid station, a gel every 3rd for the first half, every other station for the second half of the run.
I can’t do gatorade or coke, niether agrees with me while running.
– are you taking walk breaks in the aid stations?
NO!!! Jogging is ok, shuffling is barely tolerated, walking is VERBOTEN!!!
– what pace are you keeping b/w aid stations?
Whatever I can, best steady pace possible. Avg HR was z2 at LP, z3 for Kona (due to heat/humidity)
– what’s your strategy in the last hour of the bike to set up a solid run?
Same as the first hour, and the 2nd, etc. I ride steady and even.
Only difference is I try to have finished my nutrition before say the last 20-30 mins of the ride, to give it a chance to digest and settle. If possible you can soft-pedal the last mile or 2 to loosen up.
– how many cals are you ingesting on the bike?
About 450 cals / hr (I like hitting the feedbag during an IM bike ride) x ~5.5 hrs.
And lotsa electrolytes, like 700 mg sodium / hr, maybe more.
– in training, what’s your long brick? how does your run pace on a brick compare to your IM run pace?
Other than EpicMan (112/13.1), my typical long brick was something from 100-120/4-6. No real need to run long off the long bike, you are just increasing recovery cost.
I typically ran faster off the bike in training than what I would run in IM, since I wanted to simulate the physical stress of that running (higher HR, harder to digest, etc), so my training bricks would typically be :30-:40 / mile faster than my planned IM run pace.
I averaged about 30m / wk of running last season, which was up from 18 the year prior.
I did all my easy runs at IM “race” pace however, so I would be accustomed to running that “fast” (which is actually pretty slow in the grand scheme of things.) I felt like a total slacker running 8’s in training, but that’s all ya need on raceday to be an IM run stud.
Rich Strauss says that failure to run to your expected ability in IM is due to a bike pacing error, unless and until proven otherwise. Rich is correct, he knows his shit.
Good luck! You are almost there.
-M
PS - oh, the other thing. the most important thing:
YOU have to know deep in your heart of hearts that YOU can actually do it.
I had it written down on an index card as a goal for my run split for both races, and kept it posted where I could see it and read it all the time. I know that probably sounds kinda hokey, but it works.
(I had all 3 split time goals written down for IMLP - and I beat all 3 of 'em.)
I had no right to think I could run like that im my first and 2nd IM’s. But I did.
And not based on any former life as a runner (believe me, I wasn’t), or huge base or anything like that.
I just got to where that was what I expected to do, and so I did.
