2x20 workout
What are the details of this workout?
It hurts. Next question?
Add the words “A Lot” to what Ken said and I believe it’s more accurate :wink:
You’ve got to be more specific. What is your goal in doing a 2x20? LT determination? Do you use power or HR? Many people here are more than willing to help as long as you’re clear.
2x20s are typically done as race HR/power/PE intervals. They are great TT training.
Ric
Ask Jack Daniels.
It’s OK except for the cramping @ minute 21!!
Actually if you are referring to a bike workout using power or HRM it is at your Functional Threshold for 20 minutes soft pedaling for 5 minutes to recover and then 20 minutes at FT again. Typically used to detemine your threshold power wattage so you can build your various training levels.
Check out this link for a discussion of Power levels etc.
http://www.cyclingpeakssoftware.com/power411/
Ken’s right. It should hurt, but not until the final 5 minutes or so of each 20 minute session. If you are hurting after 10 minutes, then you know that you went to hard.
You need to find that point where you are surfing along that edge, but not going over it.
It’s a great workout to do, because you learn fairly quickly how fast, “to fast” is. Then the next time you do it you can back off a little bit. You will then realize that there may not be that big a difference between “to fast” and just right, but it’s that subtle control of the gas pedal that is critical to doing well in endurance events.
…and if you are hurting at 10 minutes, start praying to mamma that you’ll get through the next 10 minutes.
I will be using power. As far as the pain goes I hate to say that the pain is what I love about the sport.
I fnd that on the first one, if done properly, I consistently look at the clock at around 2:45, then at 5:30, then low 7’s, then high 8’s, then low 9’s, high 9’s , then done.
On the second one, i look at the clock at 1:10, then 1:45, then 2:30, then 3:30, then 4:30, then 5:00.
And I start praying time should go by quicker.
Then I start looking at every 10 sec. or so.
Boy does it hurt.
Ciao,
If you’re referring to the Strauss method of FT testing, the soft pedal interval is only 2 mins.
they sure hurt me a hell of a lot sooner than the last 5 minutes of the first 20 min. i would say done correctly they are very uncomfortable the majority of both 20 minute sessions. but boy, they will make you stronger and faster…one of my “favorite” workouts.
why do say the first one should not hurt at all? You are referring to 2 x 20min very near FTP right?
I have been doing these for years (since 1999 or 2000 with a power meter) and the first one always hurts a bit. I find me PE actually tracks higher on the first, then the second I seem to “open up” a bit.
But, my threshold is very near 300w right now and I did these on Saturday, and the first was a manageable hurt for sure…that said…it was a 1 hour type of hurt.
Kurt
How would I do them with an SRM?
wow, in the dead of winter? Are you reverse periodizing or do you do them year round?
Dan
www.aiatriathlon.com
fresher?..NEVER!!! must_train_hard:-)
I am very aware of my FTP would never do a 40K on the trainer, so I guess the bottom line is I am a wuss. I can accept that.
reverse? No. I do them often. Also, for me I xc ski race all winter and with the lack of snow (aka zero) it is just another (non specific) workout to try to get in ski shape.
Kurt
