The only way your heartrate will be lower when you are working harder is when you are working at a cadence that is lower than the cadence you normally use when doing hard work.
The big “O” wrote: What makes you think that is the only possible explanation?
I don’t think it is the ONLY possible explanation, just the most likely.
I’m making several assumptions, any or all which could be incorrect. I’m assuming the rider is on the same bike, in the same position, doing essentially the same activity…pedalling a bike. There are differences in the trainer compared to the road, but, these differences usually conspire to find the effort on the trainer harder than the the effort on the road. This particular rider says his HR is very low when he is at a very high level of perceived exertion (I don’t know any of this to be true, but it is the way I put together the information presented).
At higher levels of pedalling effort, heartrate increases…unless the cadence is lowered. When a given, sufficiently heavy workload is produced and the cadence is decreased sufficiently, a rider can see a decrease in heartrate, although his perceived exertion will increase. Well known, simple concept, used by most people I know that time trial…trying to find that line between a high enough cadence not to blow up, and a low enough cadence to make good power.
Another possible explanation (of having lower HR at a higher PE while on the trainer) could be: this particular rider pedalling on his particular trainer is having to recruit muscles to an extent that he usually doesn’t recruit them, in an attempt to maintain a more steady trainer wheel speed, and this muscle recruitment could result in him feeling a higher overall perceived exertion, although his work rate is lower.
Another possible explanation (of having lower HR at a higher PE while on the trainer) could be: his muscle recruitment on the trainer is more economical (dare I say it…more complete…he’s having to pull across the bottom better, pick up more, and push over the top when on the trainer to get a smoother stroke), hence the lower HR. But, the recruited musculature is sending “this is very hard for us” feedback to his brain, because these recruited muscles aren’t used to providing that workload. In this case, the rider is becoming a more complete pedaller, and he just needs to work through the adaptation period. Sounds too close to another subject though, doesn’t it?
Got any more possibilities, probabilities, that I missed? And, what do you think is the most probable reason for his lower HR at a higher PE? Lower cadence on the trainer is my guess.
