Sette Razzo 29er MTB frame Sz small. Assembled and rode once and came to the conclusion I needed a bigger frame. In like new condition. Will include seatpost, seatpost clamp, Sram X.7 front derailleur, and handlebar. Headset not included. $190 shipped to lower 48 states.
Material Full 7005 Alloy, Double Butted Main Triangle
Welding Tig Welding
Recommended Suspension Fork Travel 80-100mm
Headset 1-1/8" Standard
Front Derailleur 31.8mm Clamp Type, Top Pull/Top Swing
Bottom Bracket 68mm, English
Rear Hub Spacing 135mm
Max Rear Tire Clearance 2.3"
Seatpost Size 27.2mm
Seat Clamp Size 31.8mm
Brake Mount IS 51mm Standard Disc
Available Sizes Small (16"/40.6cm)
Color(s) Polished Aluminum
