Im 6’5 and weigh 260. My fighting weight is 200. I have signed up for races this summer and I’d like to make a real go of it. If I clean up my act and do aerobic exercise for 1-2 hours per day (swim/bike one day, swim/run the next, can I realistically shed 10 pounds a month for 6 months?
Here’s my plan. Since 1 pound is equal to 3500 calories I need to have a monthly deficit of approximately 35000 calories or 1,666 per day. This seems very doable if I do nothing more than cut out 3 beers every night and maintain a consistent workout out scheme. Perhaps I am oversimplifying this.
Can you do 1-2 hours of aerobic exercise per day, everyday?
I think you should be less specific about counting calories. Start with the big but relatively easy things like eliminate alcohol (assuming that’s easy) and then really focus on nutrition. Lots of fruits/veggies/lean proteins and watch your portion size.
Then do regular exercise. I think you should focus on doing something everyday, even if it’s not 2 hours. You want a routine you can duplicate day after day, on a consistent basis and if you start at too high a number you will not be able to repeat it.
Start easy and focus on diet, then as the weight comes off you will be able to build up your time exercising.
As Casey stated, stick with diet and steady routine of aerobic activity. Don’t get frustrated the first few weeks. It might take a month to get the furnace going. Good Luck. Drink your fluids.
I’d keep some sort of strenght training to build/maintain muscle mass. More muscles burns more calories. Plus you need to keep your calorie intake high enough to keep your body from slowing metabolism. Also the energy spent during a high intensity workout will continue for a longer time after the workout so the overall caloretic loss in greater. So hit those intervals as possible.
Just because your strategy is based on the assumption that all other food intake will remain equal. This is a big IF and in my opinion, if you are going from little exercise to 14 hours a week, without monitoring your food intake each day, is unlikely.
Your chances of compliance are related to the type of food consumed (specifically the macronutrient breakdown & the glycemic index) and the intensity of the training that you do.
You can’t go wrong with eating less and increasing the exercise. It will come off, maybe not quite as fast as you are projecting, but it will happen. Go for it man!
Possible, sure. I did it. I’m 6’6" and went from 270 to 200 for IMC in about the same length of time. I wasn’t starting from scratch though as I’d been very active before that but slipped badly with an injury and crazy work schedule. Once I was back at it I could average a good 2 hours a day of aerobic activity (bike and elliptical). We I used to be able to run i stayed around 200 in the off season and 185-190 during the season. As a 10K specialist I stayed more around 175 to 180 which was really quite thin on 6’6".
yes you can do it but your probably picking the wrong time to do it. I used a very similar strategy to get from 197-175 from Sept-Jan. However I was only using a ~700 cal a day buffer and I was not training 14 hrs a week. I set myself up so I was at a goal weight before I started my training. If you try to restrict calories & train IMO your setting yourself up for disaster as you likely wont recover properly if you are not eating enough. Dont get me wrong you will see improved performance from being at a lighter weight, but you likely will suffer from fatigue from not eating, which makes it easier to become overtrained.
I agree it is very important to eat enough calories to work out properly. I always made sure that my caloric deficit was no more than half of my excercise output for the day. So if I burned something on the order of 2000 cal working out I would make sure that I had taken in at least 1000 cal more than my daily amount. Ie 2500 cal daily amount + 2000 excercising = 4500 and I would take in 3500 or so. It was adhering to the regime religously and the long workout in the summer that really made the difference. 6 or 7 hours on the bike can really rack up the numbers even if you are taking in half the output.
Well first of all congratulations on losing the weight you already did, seems like you were very focused and that’s certainly commendable…
i agree you shouldnt be so focused on your exact caloric intact, your body is gonna demand more calories at certain parts of your training and soon racing. Just eat healthy and in portions, and as hard as it is… cut the beer out alltogether. You’ll lose those last 10 in no time. At 6’5, 190lbs your gonna be a pretty lean dude… good luck!
That’s a large deficit per day. It could lead to some binging if you really have a hard time controlling your eating, which may be the case since you are already 60 lbs overweight. I recommend taking a more conservative approach of 4-8 lbs per month. If you do better then that is great, but don’t try to take the weight off too fast. Just my recommendation.
well 1-2 hours a day is alot, but maybe not in comparison to the activity you’re currently doing. what are you currently doing, btw?
if you can run, or get on the bike/elliptical/stairmaster/treadmill and do weight bearing aerobic activity that will give you the most return for your time, you will see results provided your food intake is improved.
as for how much you’ll loose, i’m not sure. success will come with focus on being active everyday, cutting out the bad foods, and eating healthier. if you can focus on that, and get serious about it, you will get serious results.
i think the hardest thing is to be patient. and consistent.
go for it, man, and keep us informed on how it’s going!!!
If you are drinking three beers a night cutting that will save you 500 calories a day which will amount to 15000 calories a month.
But working out average 14 hours a week is unrealistic assuming that you are starting from scracth.
Good Luck
