Hi guys and gals,i’m currently on a 23 mm front and back but heard about recommendations to change to 20mm.considering comfort/RR/speed altogether…should i make a change?thanks!
Yes 20mm up front and 23 on the rear for a race wheel set up.
The 23s will probably be just as fast and more comfortable in a triathlon. It depends on several factors, including your weight and the type of tires about which we’re talking.
Remember, at a given tire pressure, the wider tire actually has less rolling resistance than the thinner tire. What you lose in aerodynamics you gain in comfort and less rolling resistance.
I would stick with the 23’s. They are far better for cornering.
lots of time saved cornering in tris huh?
as usual with tires (applies to the world of cars too) the most important thing is to get the best actual model of tire, THEN worry about the size.
Well, I do live in a mountainous area, so most of my tri’s and training have tons of canyon ridding.
