2020 Cannondale Supersix Evo, Hello Beautiful :)
Nice clean lines, but the paint schemes they’re offering are ugly IMO. Pretty cool that they tested a number of top traditional road bikes against each other in the tunnel
https://bikerumor-wpengine.netdna-ssl.com/wp-content/uploads/2019/06/SuperSix-EVO-aero-testing-results-Cannondale.jpg
Pretty good result too!
Damn right, a bike company’s own bike won their own wind tunnel test. How refreshing.
Given the general lack of consideration for aerodynamics in the design of most of the other bikes in the test group, this seems legit.
Let’s not forget the new Tarmac is actually pretty aero (as aero as the old Venge).
But not even, per Specialized’s own admission, as aero as the new Roubaix…which means the above statement is as much an indictment of the old Venge as anything.
It’s not quite fair to Trek as the Emonda isn’t an aero road bike. The Madone would have been a fairer comparison - but impressive results nonetheless!
Is this Cannondale closer related to the BMC Road Machine or the Team Machine which is their more Aero road bike? I think their Aero testing is more apples to oranges.
Having owned every Cannondale road model from Caad, Six13, Supersix and the Evo and not wanting to go to disc brakes I am gutted they aren’t bringing the rim brake option in the better carbon only a lower grade.
It’s great the Cannodale is making strides in the aero field. But, it wasn’t just the Trek Madone that they didn’t test against. They didn’t test against the Cervelo S5, the BMC Time Machine and the Specialized Venge, either. I would have rather seen those bikes in the test.
As I mentioned in an earlier post, the Supersix is their classic/climbing/traditional road bike, not their aero bike. So they were wanting to test against the same category of bikes from other manufacturers as that would be their main competition.
I imagine if someone had the tools that could overlay the data from this and the data from their system six (which they did test against the madone, S5, and venge) onto a graph and plot the points given that both data were presented as cda. But we don’t know for sure if the same sizes were used in both tests or what wheels were used. ie a quick comparison of the graphs shows the system six has a lower cda, but how much is the frame vs how much is the wheelset?
Tour magazine super bike test Venge>Madone
Cannondale test Madone>Venge
whom should I believe?
Not sure I’ve seen that one. Same Venge and same Madone in the each? I believe the Madone in the Cannondale test was the previous version (the newer version with the disc brake option hadn’t been released yet) which I’ve think I read on here is actually faster than the new one. If Tour Mag tested the newer Madone, that could make sense as it would be:
Old Madone>Newest Venge>New Madone
But someone should fact check me on that
I’d love to see my CAAD12 on that graph!
All of the bikes in that chart are the companies traditional/non-aero bikes
Traditional
Trek Emonda
Cannondale Super Six
BMC Road Machine
Cervelo R series
Specialized Tarmac
Aero
Trek Madone
Cannondale System Six
BMC Time Machine Road
Cervelo S series
Specialized Venge
When Cannonade released the System Six they did bring in a number of aerobikes into the wind tunnel
https://images.immediate.co.uk/production/volatile/sites/21/2019/03/cannondale-systemsix2019-09-1530287494356-tqcbz905xggp-1987b2a.jpg?quality=90&lb=940,528&background=white
What would be interesting to see is a chart with aero and non-aero bikes intermixed. In 2014 when Cervelo updates the R3 with the Squaro downtube they saved 7 watts compared to previous versions. But I don’t think they ever said what the difference between an S3 and R3 was in terms of drag. I think were probably getting to the point that there is a very small difference between aero bikes and classic/climbing/non-aero bikes. The former are getting faster and better at handing and the latter are getting more aero.
I think I understand what you’re saying Matt, just not the why. The prior bike was less aero, but they tested it against aero bikes. The new bike is more aero, so it’s tested against less aero bikes? That seems incongruent to me. Saying that they see those bikes as the direct competition just seems like marketing to me or possibly admitting that they don’t have anything to compete with the Madone, S5, Time Machine or Venge. That said, all of this is just quibbling over some relatively minor stuff. I’ve no doubt it’s a great bike.
Just want to clarify to make sure we are on the same page, there are two different Cannondale bikes we are talking about.
SYSTEM six → this is their aero bike which they tested against the aero bikes of other companies. It was released about a year ago and is brand new in the Cannondale lineup (is there were no previous versions)
SUPER six → this is their traditional road bike which they tested against against the traditional bikes of other brands. Cannondale has had this bike in their lineup for a number of years and just done a major remodel of it
The new SUPER six is more aero than it used to be in previous generations but it is not as aero as the SYSTEM six
You would hope your own bike would win the tunnel test. There are lots of decisions a manufacture will make when setting up their wind tunnel protocol, there is not necessarily one right answer. Do you test with all the same wheels and tires? What if some are rim brakes and some are disk, still use same wheels? What if someone are designed for specific wheels, do you use those? Or do you use the wheels and tires they come with? What size are you going to use? Are you going to use a mannequin? Are you going to test with bottles? What bottles and cages will you use? None of these questions have a “right” answer and they will affect the results.
Of course a company should optimize for their protocol, which should result in them winning that protocol, because that is what they decided the optimum set up is. It doesn’t mean that companies are cheating or not being honest, it just means they they made the optimal bike based on what they believe is the optimal set up. That is why it is so important that companies are up front with the details of the their testing, so that consumers can decide what the data actually means. One test showing Brand A having the lost drag and another showing Brand B winning does not mean one of the tests is wrong or has bad data, just different protocols.
Thanks, Matt. I was on the wrong page. Thanks for straightening me out.
Bike looks good but some interesting info from the cycling tips review
https://cyclingtips.com/2019/06/2020-cannondale-supersix-evo-details-models-prices-weights-tech-first-ride-review/
Cannondale conducted those tests in the Low Speed Wind Tunnel in San Diego, California, using complete bikes in comparable sizes and identical Shimano Dura-Ace Di2 groupsets, but with variations in wheels, tires, and cockpit components based on manufacturer spec. Some discrepancies are to be expected given the differences in rim depths — the Emonda’s 28mm-deep Bontrager Aeolus XXX 2 wheels aren’t even claimed to be remotely aero, for example — but what matters more here are the front-end setups.
Of all the bikes tested, only the SuperSix Evo was equipped with an aero-focused bar-and-stem, and given that Cannondale quotes a 9.1W saving for that component alone — relative to a conventional non-aero setup — the claimed gaps close significantly. Similarly equipped, the Roadmachine and Emonda would still be slower, but not as dramatically so, and this third-gen SuperSix Evo would basically fall right on top of the current Tarmac SL6 and R5
What’s up front matters more than what’s going on behind.
Am I the only one who has been drooling over the new cannondale logo? It’s so simple yet so beautiful.
The new logo from the '80s? :slight_smile:
https://cyclingtips.com/...h-first-ride-review/
Of all the bikes tested, only the SuperSix Evo was equipped with an aero-focused bar-and-stem, and given that Cannondale quotes a 9.1W saving for that component alone — relative to a conventional non-aero setup — the claimed gaps close significantly.** Similarly equipped, the Roadmachine and Emonda would still be slower, but not as dramatically so, and this third-gen SuperSix Evo would basically fall right on top of the current Tarmac SL6 and R5**
Except you can’t “similarly equip” an SL6 Tarmac, R5, or Emonda with that stem/bar combo, because they can’t take the brake lines into the headtube like the C-dale. Could you make them a little more aero with different bars and stems? Sure, but I don’t think you’re matching the SuperSix’s cockpit slickness with lines still in the wind. As C-dale makes this stem/bar combo standard, at least on the higher end builds (UDi2/Force eTap and up), I have no beef with them taking the credit and claiming the advantage. As for the Roadmachine, I find that an odd choice as it’s BMC’s endurance bike. The true segment competitor would seem to be TeamMachine SLR01, which happens to have a similar bar/stem setup and head-tube brake line entry point. The wind tunnel results of that model must not have been as flattering for the new SuperSix.
Have you seen the commercials for the Supersix Evo during the TdF? The ad starts and you think they’re advertising nutrition or something: the bikes look plain, the riders look plain (no logos). Just a generic bike and a generic rider…then they drop the text telling us it’s a new Supersix Evo.
The bike is a yawner. (although I’m sure it’s a blast to ride)
