I have a 2016 Specialized Roubaix and want to use 28 width. I’m ok with the width, it’s the OD of the tire that’s a problem. My current brakes are the standard Axis 1.0 and again, the width is ok but rub on the height.
Does anyone know if there’s a rim brake out there with the clearance I need?
I rode a GK slick 32mm mounted to i9 22mm internal rim (I think that was the ID) with a Shimano 6800 rear brake with no issue.
I had good luck with Tektro brakes as well, 500 series on up, for 28mm tires from Vittoria, Hutchison, and another brand escaping my memory at the moment.
