I bought this 2014 56cm Specialized Comp Ultegra so I could race ITU sprint Worlds. I traveled to Edmonton with my Falvo V that was was disallowed and needed a bike to race on. A quick trip to the bike shop and bought this bike It now has 13 miles of use. I have no need for another very nice road bike. Retail is $3400 + $699 Stages PM. Will sell for $2690 with Stages or $2190 without. Pickup from 18977 greatly preferred but will ship if desired.
Key information
UCI-legal, FACT 10r carbon frameset with one-piece carbon OSBB/chainstay, internal cable routing, and tapered headtube; full carbon monocoque fork with 3:1 airfoil shaping and straight profile for best combination of aerodynamics and stiffnessSpecialized Turbo Elite 23c tires roll like racing tires but offer incredible durability and puncture resistance through BlackBelt protectionFSA Gossamer Pro BB30 crank is stiff and light for excellent power transfer and efficiency on any terrainRomin Evo Comp saddle, with hollow Cr-Mo rails, delivers ergonomically designed, scientifically-proven Body Geometry features to allow riders to deliver power in low, aerodynamic positionsStiff, light, UCI-legal, bladed seatpost flips between 20mm and 0mm setback; plus a wide range of vertical adjustabilityFRAME Specialized FACT 10r carbon, FACT construction, aero-shaped tubing, compact race design, tapered 1-1/8" to 1-3/8" headtube, internal cable routing, carbon OSBBFORK Specialized Venge FACT carbon full monocoque, OS race for 1-3/8" bearingHEADSET 1-1/8" upper and 1-3/8" lower, stainless steel cartridge bearings, w/ custom Venge top capSTEM Specialized Expert Pro-Set, 3D forged aluminum, 4-position adjustable, 4-bolt, 31.8mmHANDLEBARS Specialized Tarmac Comp, alloy, 140mm drop, 85mm reachTAPE Specialized Classic WrapFRONT BRAKE AXIS 2.0REAR BRAKE AXIS 2.0BRAKE LEVERS Shimano UltegraFRONT DERAILLEUR Shimano Ultegra, braze-on, 11-speedREAR DERAILLEUR Shimano Ultegra, 11-speedSHIFT LEVERS Shimano Ultegra STI, 11-speedCASSETTE Shimano Ultegra, 11-speed, 11-28CHAIN KMC X11LCRANKSET FSA Gossamer Pro, BB30CHAINRINGS 52/36BOTTOM BRACKET OS integrated, sealed bearingsPEDALS Nylon flat test ride, loose ball, w/ reflectorsFRONT WHEEL Fulcrum S5REAR WHEEL Fulcrum S5FRONT TIRE Specialized Turbo Elite, 60TPI, foldable aramid bead, BlackBelt protection, 700x23cREAR TIRE Specialized Turbo Elite, 60TPI, foldable aramid bead, BlackBelt protection, 700x23cINNER TUBES Standard presta valveSADDLE Body Geometry Romin Evo Comp, hollow Cr-Mo rails, 143mmSEATPOST Specialized Venge Aero, FACT carbon, flippable 20/0mm offsetSEAT BINDER Venge integrated seat clamp assembly
