the stages only measures 1 leg. it is a brand everyone speaks lowly of.
one of these is not like the others
Noted, and I do agree.
Do you have any insight on the 10 vs 11 speed crank set question? If i’m using 10 speed cassettes today but wanting to upgrade in the future - am I better off with a 10 or 11 speed crank?
I think P2M will estimate your L/R power output. If this is important to you, the only option of the 3 you mentioned is the Vectors. I have the exact same bike and crankset. I am also looking for a powermeter and narrowed it down to the Vectors and P2M (can’t go with Stages because the crank uses a pinch bolt).
How easy is the transferability and calibration of the vectors? I am leaning towards P2M because I don’t want to deal with installing the Vectors (need to have a torque wrench) when I ship my bike to a race.
Just don’t buy a Stages. I fell victim to that and got one. It didn’t take long for me to realize my power numbers were way off especially when the power went up… I saw the light and got a powertap.
What is this 11 spd crank you speak of?
Long story short - I was looking at picking up a Ultegra crankset for my P2 so that I could use the Stages PM. The Ultegra 6800 is stated to be an 11 speed crankset - which then caused my mind to explode. Now I’m trying to make sure that whatever PM I get, assuming it’s crank based, will work with either 10 or 11 speed cassettes!
Hi mdub,
many chain rings are both 10 and 11 speed compatible. We carry Praxis Works and Rotor chain rings, for example, both of which work with 10 and 11 speed. The chain ring spacing between the big and the small ring remains the same.
Happy research and choosing!
Best
Nicolas
I run an Ultgera 6800 11spd crankset with an otherwise 10spd bike (two bikes actually). It hasn’t missed, or even hesitated on a shift once it was set up properly.
The other thing to keep in mind is that the left arm of a shimano stages crank can be put on ANY current shimano crank. It doesn’t need to be an exact match.
Thanks Nic! That’s what I was hoping to confirm.
Thanks Beston. I’d heard that about being able to put shaman crank arms on any shim any cranks - thanks for confirming on the shifting too!
Yep, the spindle that shimano uses are identical between models. I’m using a Dura Ace 9000 stages left arm with an Ultra 6800 crank.
I’ve also put the stages crank arm on a 6700, and 5600 crank.
I have a 2010 P2. I installed a Power2Max 2 years ago with Rotor cranks. I kept the chain rings the same but will probably switch out to Rotor rings next year. Flawless!
Good to hear! P2M is seeming like my best choice. I think I will do the Rotor crank w/ Praxis rings.
On my 2007, I just picked up a Quarq Elsa off the classifieds. I couldn’t be happier. It’s a great unit. I did move my 54T ring over to it, and used my existing bb.
Powertap.
Easy to swap bikes (just change wheels).
Put one is training wheels and race wheels off you go.
If there any issue you still can ride.
Pricing wise, if you shop the pricing is not much different than the crankbased PMs based upon separating the PT and Wheel Cost.
I have 3 PT wheels and I am VERY happy with the service of them.
Went with the Power2Max - FSA Gossamer Classic. I’m really excited about adding this to my training and racing - couldn’t pass on the great deal. Thanks for everyone’s tips and help on this!
Which did you select?
The FSA Gossamer Classic. I went with the Praxis rings - 52/36.
Hey, if you don’t mind how has this setup worked out for you. I have the exact same bike and am a little overwhelmed with the choices. I was also looking to get a Stages but by the time I replaced the cranks it is around the same price as the power2max.
I’ve been very pleased with my choice. As mentioned above I went with the Power2Max (FSA Gossamer Classic) with the 52/36 Praxis chain rings.It was very easy to install and fit my BB perfectly.
I’m really glad that I have a crank based PM and I’ve enjoyed the extra data I’ve been able to capture getting to see my power balance since it captures each leg, not just the one that you’ll get with a Stages. Not to knock that power meter, but P2M definitely gets my vote.
Let me know if you have any specific questions - I’d be happy to lend any advice or experience on selecting a PM for my P2.
Excellent, thanks!
