Hi Everyone - My baby needs to go. I did 1 TT this year and only 2 TTs the year before. I rode the bike as a road bike before that, and it worked great. Arguably, Storck had the first “aero road bike”.
This is the frame: http://www.storck-bicycle.de/...sub=3000&objekt=
It’s outfitted with a 3T Auro pro front end. The fork was switched to an ENVE 2.0 road to improve handling. Campy record brakes. The front der is campagnolo record 10spd, the rear is campagnolo centaur 10 spd. It has sram gxp aluminum crankset (172.5 mm). Adamo saddle (the best).
There are small chips/scratches in the paint as you’d expect in any 2.5 year old bike. Pedals not included.
It is one of the stiffest time trial bikes out there and comes with an excellent craftsmanship pedigree. STIFF AND FAST.
In the realm of time trial-specific bikes, aerodynamics is always hovering at the top of our short list of necessities. Markus Storck and his talented team of engineers are well aware of this crucial ride characteristic, but they also know that a sleek and drag-reducing design means nothing without stiffness. For that reason, they created the Aero to be the “stiffest carbon time trial bike in the world,” in addition to being exceptionally fast. We know that this is a lofty claim, but once you begin to see the engineering that has gone into the development of this machine, you’ll begin to see exactly what they mean.
The Aero was constructed from Storck’s own UD carbon fiber, with the UD designating “uni-directional.” Compared to a woven carbon fabric, uni-directional carbon is oriented as it sounds, with one direction, or on one axis. And while this makes the production process dramatically more complex in regards to load path and force direction determination, the payout is worth it to Storck. You see, compared to woven layups, uni-directional fibers tend to better stiffen frames, while also improving the characteristic of vibration dampening. And incredibly, this is achieved at a much lower overall weight. However, Storck was far from finished in any of these regards.
Let’s approach the Storck layup process in a short series of steps. First off, Storck begins the design with 3D CAD imaging. This digital process provides Storck with the precise data and dimensions necessary for the development of the mold. From there, the UD fibers are soaked in resin and hand-placed into the computer-generated mold. Once placed in the mold, the fibers are heated and pressed into the “V-profile” tube shapes with an air channeling tool. Afterwards, the fibers are smoothed over by hand, ensuring an unprecedented level of preciseness and detail to the layup.
Moving into frame specifics, you’ll find an oversized bottom bracket juncture that efficiently transfers power to the Aero’s rear triangle. And not surprisingly, we see the reoccurring theme at work again of increased weight reduction coming as a result of increased power transfer. At the aerodynamic seatstays, Storck gracefully originates them from a box-section above the brake caliper, before transitioning them into a flattened profile down toward the dropouts. And again, this results in increased comfort via vertical compliance, in addition to a higher level of lateral rigidity, and a reduction in drag. Additionally, you’ll find that the Aero is one of the most painstakingly rider-tuned frames on the market. For the chainstays, Storck applied its “aero super size,” design, which is essentially an oversized, box-section construction that directs rider energy output directly to the rear wheel. Rounding out the construction is electronic-drivetrain-specific internal cable routing.
Wheels:
The rear is a campy freehub body. Details about the wheels and tires:
Front=White Ind. H2 F Black hub laced to a PSIMET 50mm Front Tubular rim 20f/RadialX using CXRay-Black spokes and DT-12mm-Brass-Silver nipples
Rear=White Ind. H3 R Black hub with CAMPY freehub body laced to a PSIMET 58mm Rear Tubular rim 24r/2X using CXRay-Black spokes on the Drive Side and laced 2X using CXRay-Black spokes on the Non-Drive Side and DT-12mm-Brass-Silver nipples
Tires = Vittoria EVO CS 700x23 Tubulars w/Extenders
http://s1280.photobucket.com/...zps6f21f43c.jpg.html]
