2011 Trek Speed Concept 7.0 Medium $1000
PayPal only Please. FREE SHIPPING
Used and in good condition. 2 owners and neither of us used it much. Father/son owners.http://www.ebay.com/itm/2011-Trek-Speed-Concept-7-0-Triathlon-Time-Trial-Bike-Size-MEDIUM-1f-/282602258825?hash=item41cc684189:g:ObcAAOSwVRNZiJuBGreat performance bike for triathlons or time trial eventsNormal wear and tear with signs of use throughoutFew marks on the bike and all photographed. Photos 8-9 show chain drop/suck wear it got caught under crank. No crack and stiff to the touch. 5mm is the largest markFrame TCT carbon KVF tube design and fork is carbon with aluminum steer.Upgraded Sram grouppo (Originally all Sram Apex). Sram 500TT shifters 2x10 speeds. Sram Force front/rear derailleurs.Sram Force double crankset 172.5mm arms 53/39t 130 bcd-normal wear and should last several more yearsSram Red front brake caliper and the rear brake is Bontrager proprietary brake under the bottom bracketCassette Shimano Ultegra cs-6700 11-23t 10 spd in great conditionBB90 bottom bracket bearings rotate smoothlyUpgraded Bontrager TLR 700c wheelset. You will need new rim strips to go tubeless. 24/24 bladed spoke count.Continental Hardshell 700x25mm tires with presta valve inner tubes. Tires can last a year or two moreSpeed concept aero skewers with some minor marks on themDuotrap cover plate is missing in photo 11.Vision tt stock saddleBuilt for height of 5’8-5’11Measurements- Stem 110mm ±6 deg. TT center to center c-c- 54cm. ST from center bb to post clamp-53cm. HT from fork crown to stem cap-9cm.Plenty of room for adjustment on steer tube.Seatpost has plenty of height adjustmentAfter arrival I recommend a bike shop rebuild it and do a tune up just for good measure. It requires many Nm specs for re-tightening bolts and a shop would specialize in rebuilding it properly.Item ships FedEx and boxed by a local shop. Item ships with insurance and signature.Questions? Please inquire
Is this still available?
Thanks,
Matt
