2009 vs 2008 Spec. Transition
I am looking at the Specialized Transition Pro and after trading in the wheelset the difference is $300 more for the 2009. The 2008 is 7800 Dura-Ace and the 2009 is SRAM Red. I’m leaning toward the 2009.
Opinions? Which model is better?
Here are the links to the specs:
2009
2008
The seatpost collar is fixed for 2009.
I’m on my third 2008 s-works transition. The first two both had cracked seatpost collars. One reason the bike was delayed in the first place was the seatpost collar. That will be $300 well spent. :slight_smile:
Plus, that’s less than the difference between 7800 and Red anyway…
Thank you guys. What about the difference in bars? 2009 is visiontech and 2008 is an in-house base and Zipp clip-ons.
The basebar on the '08 is very blah… along with those carbon break levers…
I also had a frame crack around the seat collar. Specialized was great about sending a replacement though.
If I were you, I would pull the trigger on the 2009.
