They both fit. Both about the same price. Which to choose?
P2C. Have one and love it!
The B2 is so much more bike than a p2 DA.
B2 has a more aero profile and the feel of the ride is awesome. I have owned P2C which was nice but I so prer the felt. Ihave produced better results with power and times
They are pretty evenly matched bikes. Aerodynamics, weight and components are all pretty much a wash I suppose. To me it’s a decision of details:
- Do you have a good mechanic to install the Bayonet front end and check it every once in a while? If you do, then that is definately an advantage in favor of the felt.
- Which side of the size run are you on? For me, going with the Cervelo would have meant more a spacer or two, where as the Felt was spot on(they’re almost 2cm different in stack in the 51 vs. th 52)
- Aerobars: It looks like the Felt comes with an s bend aerobar, whereas the Cervelo comes with skibends.
- Which one do you like more? Do you like the yellow of the B2 or the red/silver of the P2?
Good luck with the choice from a B2 owner. You can’t go wrong with either.
They’re both fine bikes. I have a P2C that’s fast and comfy.
I prefer the ultra clean lines of the cervelo. Not flashy, all business.
Whichever one you would be prouder of owning is the one I would get.
Even an average/hack mechanic that can follow the assembly video can install the Bayonet, once installed it doesn’t need any more frequent checking or maintainence that a conventional headset. I’d be more concerned with someone truing their wheels or installing a new chain, two tasks that will likely be needed over the course of owning both bikes.
I agree, you can’t go wrong with either.
-SD
