2007 Transition Pro Frame/Fork Weight
I have scoured the internet trying to find data. Anyone know what the weight is for a medium Transition Pro (Frame/Fork)
from here: http://weightweenies.starbike.com/forum/viewtopic.php?p=445162
TRANSITION PRO FRAME 1560 GRAMS INCL HEADSET
FORKS 500 GRAMS
SEATPIN 250 GRAMS
BRAKES 300 GRAMS THE PAIR.
STEM 175 GRAMS
THE BIKE IS VERY STIFF AND TRANSFERS THE POWER BETTER THAN ANYTHING I HAVE RIDDEN BEFORE. ITS VERY AERO AND AT HIGH SPEEDS OR DESCENTS YOU REALLY NOTICE THE DIFFERENCE.
THE BRAKE SYSTEM WAS A PAIN TO SET UP BUT NOW ITS WORKING THEY ARE QUITE POWERFUL.
HANDLING IS NOT AS SHARP AS A ROAD FRAME BUT VERY STABLE.
ON MY FIRST RIDE THE REAR WHEEL KEPT SHIFTING EVEN WITH THE QR ON REALLY TIGHT. THE DROPOUTS ARE FACING REARWARDS AND ARE VERY POLISHED. I HAVE USED A WASHER WITH A BIT MORE GRIP TO SOLVE THIS PROBLEM BUT THIS IS THE FIRST TIME I HAVE EXPERIENCED THIS PROBLEM ON A BIKE.
CLIMBING IS EXCELLENT WHETHER YOU ARE SAT DOWN OR OUT OF THE SADDLE.
INITIALLY WAS WORRIED ABOUT THE EXTRA WEIGHT OF THE FRAME BUT MY CLIMBING IS ACTUALLY FASTER ON THIS BIKE THAN MY ROAD BIKE WHICH IS 2 POUNDS LIGHTER.
THE FRAME USES INTERNAL CABLE ROUTING AND YOU NEED TO USE AN OUTER CASING ALL THE WAY THROUGH THE FRAME FOR THE GEARS TO WORK PROPERLY.
CHEERS FROM ROB.
you need to use the set screws in the rear drop out to keep it from slipping, not a washer
And this one
Is my digital gram scale off?
I just got done weighing a medium s-works transition- here is what I got:
Frame- headset bearing removed, bb bearings still in,- no hardware removed- 1652 grams
Fork- 541 grams (uncut)
Seatpost setback model- 303 grams
Seatclamp 50 grams
Front cable guide 32 grams
Headset 48 grams
Crankset 580 grams
Brakes 136 grams each
right on!
