2006 Scott Plasma Pro size 52 (small), stock everything except for the aero bars which I switched to Vision ski tip. I have the Original Profile Carbon Strykes that came with the bike if those are your preference. All Shimano Ultegra with Dura Ace shifters, no down-spec’d brakes or crank here. The seat mast measures 66 cm from the Bottom Bracket center to top of the mast, on top of that you still have 4 cm of adjustability upwards on the seat post hardware, so after it’s all said and done you have 70 cm, and that’s to the top of the seatpost, not the top of the saddle. Or you could get the ‘extended post’ from Scott (mentioned in Slowman’s review) and get more adjustability. My inseam is 32.5 and I don’t have the length anywhere near maxed out. As for the steerer tube, there are 9 cm above the top of the head tube available if you ride with spacers (gasp).
Slowman did a review of the bike which you can see here: http://www.slowtwitch.com/...ma_for_2008_184.html – the same frame, different paint scheme.
$2000 and we’ll split the shipping.
