2005 Javelin Arcole Review
2005 Javelin Arcole, size 57, 700c Review
(Disclaimer - I neither work for nor do I sell Javelin bikes, I just felt like reviewing this bike for ST readers.)
This is my fourth TT bike in as many years, and I believe that I have finally found nirvana. I like aluminum. I always have ridden an aluminum bike, even in my MTB days (hardtail of course). Retail is $1800.00 for the frame fork. In San Diego you can find the Arcole at Wheels on Wheels.
When I first saw the Arcole back in 2003 at Dave Bunce’s Bicycle Sports shop in Encinitas, I was very impressed. He showed me the bladed seatstays and explained how Scott Warren had actually designed the frame in the wind tunnel, from the ground up. The first thing that struck me with this frame is the dramatic extruded aluminum tubing, which allows for the bladed top tube, seat tube, down tube, and seat stays.
Building upon the aerodynamics, Scott chose to use a 1" headtube to further blend the head tube into the top/down tubes with elegance. Although the aero Zero fork is included with the frame, I use a Reynolds Ouzo Aero Pro. The headset is integrated and very clean. All cables are ran internally, without stops, which allows me to run the powermeter cables internally. I like this.
The Arcole has custom aero frame tubes of 7005 butted aluminum which Javelin claims makes it the strongest, most aerodynamic frame possible. Includes a FSA integrated headset in a 1" Hammerhead headtube, and a previously mentioned Zero aero carbon fork. The seatpost is also 25.0, very narrow, and a very nice Selcof aluminum seatpost it included with the frame, I use a carbon Look Ergopost. USE and Corima also make 25.0 carbon posts.
The geometry matched the Abici I previously used: 74.5 degree seat angle, with a 73 degree head angle.
Weight is just over 3lbs.
THE RIDE:
Stiff, compliant, comfortable. Absorbs road vibration well, not sending every jolt to the rider. Out of the saddle the chainstays showed no flex, very stiff for TT starts and TT turnarounds.
The frame feels very natural and predictable, not at all sketchy. I felt minimal movement in the bottom bracket area even when climbing out of the saddle. My second ride on the frame was a local 10 mile TT, it felt very natural and I never noticed the frame at all when racing - nor did I notice any road vibrations or frame flexing.
INSTALLATION:
Installation was a breeze, there were no tricks with cable routing. The seatpost binder is integrated and made very well, not putting undue pressure points on my carbon post. The interal cabling is routed so that a full cable housing piece runs from the shifters all the way to the bottom bracket (internally).
WARRANTY:
Javelins come with a limited lifetime warranty.
GEOMETRY:
http://www.javbike.com/beta2/geometry.php
IDEAL BUYER IN MY OPINION:
Powerful short course triathlete or road time trial racer who likes a “slacker” position in a stiff yet compliant frame.
This frame is in the same class as the aluminum Cervelo P3, Guru Trilite, and Felt B2.
http://www.rotorcranksusa.com/javelin/thumbnails/dscf0001.jpg http://www.rotorcranksusa.com/javelin/thumbnails/dscf0002.jpg http://www.rotorcranksusa.com/javelin/thumbnails/dscf0003.jpg http://www.rotorcranksusa.com/javelin/thumbnails/dscf0004.jpg http://www.rotorcranksusa.com/javelin/thumbnails/dscf0006.jpg http://www.rotorcranksusa.com/javelin/thumbnails/dscf0007.jpg http://www.rotorcranksusa.com/javelin/thumbnails/dscf0008.jpg http://www.rotorcranksusa.com/javelin/thumbnails/dscf0011.jpg http://www.rotorcranksusa.com/javelin/thumbnails/dscf0013.jpg
SAAAAAWEEEEEET ride
thanks for the review - nice ride! I have now made it my second fantasy bike, behind the lucero. Some questions:
what were your other 3 tt bikes?
do you use the arcole exclusively now?
would you use the arcole for a 112mi TT? If not, what wd you use?
is the arcole the same as the more expensive barolo besides carbon triangle on the barolo? did you consider this frame? did you go for arcole b/c of price or b/c you dislike carbon stays, or other reason?
Specialized S-Works M4, Santa Cruz Roadster TT, Abici Time Machine (see a pattern here?)
For TT racing, yes.
Yes, I ride it for 3-4 hours comfortably, so 112 should be fine. It is very comfortable.
The Arcole is more aero in my opinion, has the aero bladed seatstays that the carbon stay models do not.
Went for the Arcole purely based on aerodynamics, knowing that it was designed in the wind tunnel by Scott.
Gary,
Off topic question. I just got the Polar power meter. How much does your 7800 DA chain weigh and how many links.
BTW - Awsome bike. 3 of my four bikes are black (all Felts). I really like the look. But I have also thrown in a little red (tires, …)
I’m weak.
"Off topic question. I just got the Polar power meter. How much does your 7800 DA chain weigh and how many links. "
I use the default settings in the book for chain weight/length, just be sure you measure your stays correctly.
Note that I also use a Powertap Pro on the same bike (you can see the mount on the stem) for training rides on the trainer. The power display between models is pretty good, on the road.
I saw one for the Shimano DA 9 speed chain, but not the DA 10 speed (7800)? Maybe my meter is old?
I believe it is the same, the settings. I use a 9 speed chain however.
I thought the chain changed. Maybe a little thinner on the 7800?
Anyone else know?
hey gary, you probably shouldn’t advertise about that integrated headset on your arcole. What would the King colonel sanders bunnyperson think.
He would understand, this is a special purpose bike.
Gary:
You don’t work for or sell Javelins, but they advertise on your website. That would be important information for most people trying to gauge the merits of your review. What else is a disclaimer for, if not to disclose information like that?
Gary, that bike is sick!
Are those self-modified Hed bars?
I’m drooling.
That Javelin banner on www.timetrial.org is non-paid, no cost as a gesture of thanks.
Javelin helped me to procure the frame, and I was not asked, nor under any obligation to review this frame.
However, as I stated, I do not sell their bikes, nor do I work for Javelin.
HED bars,
I made the extensions, and installed two washer spacers under the elbow cups to angle them downward.
