2004 404's/2005 Ksyrium SL's
So I bought a powertap setup for training and racing and no longer need either wheelset.
Ksyrium SL’s 2005 700 Shimano Clincher very good condition $375
Zipp 404’s 2004 700 Shimano tubular, non-dimpled, no stickers, very good condition, carbon pads used only. The rear has a conti-comp 22mm black tape glued on with ~200 miles in very good condition. The front has a conti 19mm glued but this will need to be replaced, the valve is broken (can still pump up tire) and the base tape has started to seperate from the rubber (the rubber is good, this would be a good tire to send to http://www.tirealert.com/ to repair and use as a spare for $20). **$700 **
I’ll be able to post pictures today or tomorrow, but if interested I can email you some pictures too.
-Andrew
Here are pictures of the wheels:
http://www.angelfire.com/planet/ntm/parts/
pm sent
bump
are those scratches I see on the front Ksyrium spokes?
