2 worthless questions
Besides biking more to get faster, or losing weight, or hiring a coach, or doing a thead search… does anyone know the answer to these two questions?
1.) What is the difference in rolling resistance between using latex tubes and butyl tubes on a tire like the Pro2Race?
2.) And power and comfort aside, how much does lowering the front end of a bike by removing a half-inch of spacers actually affect your cda? Talking averages-- not specifics.
                             just curious.
  1. Not enough that you will ever notice unless you name is Jan, Tyler, or Lance
  2. No real way to actually tell. I would guess not a lot. - Better answer, Not enough to offset the loss of power or comfort.
Welcome to Slowtwitch.
No idea on question #1 sine I use Tufo tubular clinchers.
now for #2 - it all depends on where you are starting from. I once “raised” my front end from 17.5cm to 9 cm drop and my back raised less then 2 inches. When I was at 17.5, my shoulders were curving down, not my back, to get down to the aerobars. This also restricted breathing. So raising the pads didn’t raise me up all that much and helped me breath better.
just curious.
  1. For a Vittoria Open Corsa EVO CX (23) the Crr for a butyl tube is ~ 0.00307 with a Michelin Latex tube size (22/23) the Crr is ~ 0.00261. For a Velo Flex Pave the respective Crr values are 0.00376 and 0.00318. Both ~ 15% improvement with Latex. Don’t have data on the PR2. These were measured on Tacx rollers - smooth PVC. On a real road the Crr would be ~ 2X ??
    If the same tire is used on both wheels, you and bike weigh 200 lbs., and were moving at 25 mph the power savings would be ~ 4 watts on a smooth surface (~ 8 watts on asphalt) using the Vittoria.
  2. Based on wind tunnel testing I did in Nov a change in drop of ~1 cm saved ~ 30 sec per hour.
