2 Man TT questions
I will be competing in my first 2 man TT in a few months and have two questions. (My partner and I are almost dead even in ability which should be a plus)
  1. How do you determine effort or speed? My thought was to pick a predetermined speed (dead flat course) and maintain that with the option of adjusting up or down while on course.
  2. How long for each pull? (40K)
Thanks
Here is a thread that popped up awhile back. A lot of the answers were not for two man, but that was the original topic, and a lot of the responses are on topic…Maybe something to be gleaned from this one, and maybe jumpstart the discussion again…
http://forum.slowtwitch.com/gforum.cgi?post=1025291;search_string=;#1025291
Never heard of a 2 man TT. Is it like a relay?
Or are you talking:
http://www.addiscombe.org/nontext/tandem/tandemphoto2.jpg
Perfect! Thanks
Communication must be intuitive. Telepathic.The two-up is among the most difficult and demanding disciplines in cycling.
Remember the Trofeo Angelo Baracchi? Lemond and Hinault parred together as a two man team. Incredible. All the top stars parred together. Anderson and Yates. It was an amazing event.
In general, according to Eddie Borysciewicz, author of *Bicycle Road Racing, *the consummate guide to bicycle racing, a two up effort should ba about 30 seconds each- 30 second pulls. The effort is flat out. Each man buries himself. The exchanges from worker to relief must be instantaneous. Failing to gain the wheel of the man on the front is the ultimate calamity- no rider is resting here. The team has disintigrated at this point. That is to be avoided at all costs.
The weaker rider sets tempo, especially into the wind and on the climbs. Always let the weaker rider make the effort on an incline. The stronger rider shall make the weaker rider better by offering shelter. In the penultimate moments the stronger rider may need to assume leadership and take missed pulls, but this can only be sustained for a matter of minutes- maybe five minutes of effort, taking about three turns from the weaker rider.
Beware of wind direction. In a powerful crosswind a linie formation benefits no one. Practice an echelon or demi-echelon in a powerful crosswind.
In preparation you must practice one thing: The exchanges. This is the greatest opportunity for loss. A well-drilled team changes lead seamlessly and instantaneously. The lead rider is on the back and in the slipstream recovering with uncanny speed.
Be certain the lead rider *never accelerates to open a gap inadvertantly. *Egos must be kept in check here. As soon as a gap opens, the event is over- it has become an individual effort.
The two-up is an incredible event. Rare and difficult. An amazing effort. Best of luck in this- it is a very exciting opportunity…
http://www.veloarchive.com/races/races.php?raceID=baracchi
“Be certain the lead rider never accelerates to open a gap inadvertantly.”
absolutely an opportunity to gain or lose time
i can’t stand it when that happens on a group ride unless it is an intentional attack or course
Pinole TT by chance?
absolutely. Gapping a rider off is an act of open aggression.
Good stuff - thanks
yeah or a lot of the time someone who just does not understand how to pull through correctly
True.
That’s what I always claim… :open_mouth:
There’s always a lot of discussion about 2 man TT’s…how long to pull through, etc…
Here’s the reality: it doesn’t really matter. The reason there’s no consensus is that there IS no good way to do a 2 man TT. That’s why if you look at the average speeds of a 2 man TT, they’re nearly identical to the speeds that the same single riders can do. With that said, it definitely feels easier with longer turns at the front, closer to a minute. 30 second turns at the beginning is a recipe for blowing up, IMHO.
I’d agree wholeheartedly with that. Was in a 4-man where we lost our 4th a few miles in. With 3 of us, the tough part wasn’t being on the front, it was drifting back and having to accelerate and go anaerobic to get back in line at a high speed. With 30 second pulls in a 2-up, you will have only 20-25 seconds to recover. I’d personally go for 60-120 second pulls.
  1. start moderate for 5 minutes, then go as fast as you can, one of you will start to drop back, at that point, divide up the length of pulls to 30/70%, keep the speed the same between the pulls however
  2. keep the pulls short, but not too short - maybe 15 seconds
“it definitely feels easier with longer turns at the front, closer to a minute”
Keep the pulls shorter and harder, it should feel like an individual 40k TT
If you have pulls that are too long, you will end up slower
Case in point … ever have someone pass you in a race, only to overtake them quickly and then play leap frog until the finish? Same thought, pretend you are racing your partner and you will go as fast as possible. Still draft, and make the transitions smooth, but spend only 15’ish seconds in the draft before taking the lead. 30 seconds is OK, but the recovery in the draft is mentally deceiving, it makes it harder to take over the lead when you are drafting. You can’t really get much of a break in 30 seconds anyway, so better to keep the speed fast and not recover more than 15 seconds.
This all depends on the terrain and head winds of course.
I agree with Gary, I would use shorter 15-20 second pulls. I’ve done as few of these and 30 secs is a long time when you are on the front doing 30mph. I never fix the pull period but normally peel off just as it’s getting painful mainly so that the rider who has just finished his turn does not get gapped whilst he is recovering. Don’t be afraid to change the pulling periods as the stronger rider emerges or someone needs a little longer to recover.
Communication is everything.
15-20s pulls? Thats silly. Heres a good workout to show why thats silly. Get on the trainer, go 15s on 15s off for 45 mins. Now do the same work out, 2 min on, 2 min off. Then tell me which one you were able to hold a more constant effort on.
Like someone else said, 2 man times are hardly any different from solo efforts and should be ridden accordingly. Each rider should pull as in their solo TT tempo and swing off at that point where they would soft pedal in a normal solo TT effort. And no one is naive enough to believe that people dont soft pedal /lose focus etc in TTs :slight_smile:
IME (which is numerous) fixed time/length rotations dont work bc even well matched riders will start to drift in ability at VO2+ max levels and at that point its easy to get mad at your partner for pulling thru too hard/too slow etc. And cussing definately doenst make u go faster.
Really ? There is a difference in time between single and 2 man TT’s. Over 40km 2 up normally is 1-2 minutes faster if done correctly. If you’re not seeing an improvement than you are not going hard enough. I can’t speak for anyone else’s experience although Gary T is saying 20-30 secs ish and he knows what he’s talking about. I’ve placed in enough TTT’s to know what works from perspective for me as well.
There is a caveat to all of this though; it depends on the course typography, distance, and the pairing. If you are doing 60 second pulls over a 10 mile course than you are missing the point. It’s not just about a steady effort alone -its about suitable recovery and this has to be tailored on the day.
Gotta agree with you there. When I did 2up TTs with another rider of equal strength, we were about 1:30 to 2 minutes faster (without aerobars, I often used my road bike as it was one of the first events of the season) than we would have been individually (with aerobars) over the same course. Here is how we did it:
20-30s pulls.
communicate
never surge.
ride side by side up any significant hills so we could talk to each other and see if we needed to adjust.
lead rider pays attention to the wind direction and adjusts which side he drops off the front, as appropriate.
Also, a TTT is not a steady effort event. It is sprint, recover, repeat 60 times.
"Get on the trainer, go 15s on 15s off for 45 mins. Now do the same work out, 2 min on, 2 min off. Then tell me which one you were able to hold a more constant effort on. "
You may get a draft, but you do not get 2 min off.
If you hold a constant pace, and go 30% harder when taking a pull, you will go faster as a team. To do this right, short pulls work best.
Even in a 4-man TTT last year, we did 15 sec pulls, and for the state championships this year, 2-man TT, we will do 15 sec pulls at 30 MPH.
