So, I wrote this to Josh after the “Ask Josh Anything #003” Marginal Gains Podcast. He asked me to post it here because he thought it was a worthwhile topic for debate. So…
Hi Josh,
in a rare occurrence, I’m going to disagree with you. Well, more specifically, I’m going to disagree with your methodology. You said on the “Ask Josh Anything #003,” “That 10T cog really shouldn’t exist,” but in making that argument you focus solely on the frictional aspects of chain articulation in comparing an 11T vs 10T cog. But this leaves out a (potentially) significant consideration - aerodynamics. When considering 1X vs 2X drivetrains, any discussion that neglects the frontal area savings of removing front derailleur & derailleur hanger is incomplete. But frontal area also plays a role when considering chainring and cassette sizing for 1X drivetrains.
We know that the drag on a flat plate is not insignificant. Comparing a 50T x 10/28 drivetrain vs a 54T x 11/32 drivetrain, the frontal area differences between the 50T vs 54T chainrings should be considered. And even the frontal area differences between a 10/28 cassette and an 11/32 cassette are relevant, especially on a disc wheel where any additional FA “replaces” the “clean” surface of the disc. This is because the 10T is, inherently, a “high speed” cog. A rider in 50-10 is going at speeds where 90%+ of the resistance is aerodynamic, so it doesn’t take much of a FA difference to overcome the frictional losses.
There’s also the potential jump in FA from needing to make the shift from a short–>medium or medium–>long cage rear derailleur. These bumps in FA area all marginal, but they can add up, especially at high speed.
If 10T doesn’t have a place, it’s likely in gravel-type situations where speeds are lower and the difference between a 40-10 and a 44-11 is even greater because of the greater deflection on the chainring as well as the cog. But on the road side, with higher speeds, even marginal differences in FA can be potentially significant, and dismissing the 10T without acknowledging the reduced FA of a drivetrain with a 10T cog seems reflective on an incomplete analysis.
The 10T cog may still lose out at the end of the day. But in making that statement without considering the FA of the drivetrain, I think you’re leaving some important details out.
All the best,
Jordan
