That sounds yummy!
Hydrate on a cool 10K?
Do you drink anything or just keep motoring?
Cool 10K I keep motoring, but that’s me.
Cool for me is under 50°F
jaretj
lets just assume you are going to run around 40min +/- a few minutes. if thats the case the most important thing is that you were hydrated going into it, its a pretty short race to worry about hydration. if you could wet your mouth a couple times though, that would be optimal. also, if the race is not until oct 12’ then you have more than enough time to create a periodized training program so as to allow for a number of tempo runs at different distances and a number of interval sessions. for a 10k i wouldnt recommend anything under 300m intervals unless you are focussing on running only and not doing triathlon stuff. triathletes tend to want to mimic training programs that work for people who just run, if you do all three sports you have to prioritize from the list of interval workouts you could possibly do.
10K is long enough so that there really is no good substitute for volume. Good training means running alot.
I always found a 10K really hard to pace properly, even when I raced a lot of 5 mile XC courses in college it was hard to adjust for that extra mile.
For track workouts, do mile repeats at race pace and 400 repeats at your mile pace.
As for racing, you should start hurting just past the one mile mark, if not you are not going fast enough.
You should seriously feel like quitting at the 5k mark, if not you are not going fast enough.
I’ve had okay results with intervals just 1X per week.
work out = 4 x 1 mile @10 sec faster than 5k pace with huge rest in between each mile.
race strategy = All my recent 10k’s have been done with the “go out faster than planned average pace” and then hold on for the second half. I don’t know whether or not it would work better to start at a more conservative pace. If you’re doing a 10k with plenty of hills, that might play into your plan.
Take an on course drink that contains carbs. swish it in your mouth and spit it out. I have read stuff that suggests that it** may **help with performance. A study was done with a 1 hour cycling test. I don’t see what it would hurt as long as it doesn’t slow you down when you grab it and put it in your mouth.
What I read suggests that sensors in the mouth trigger something in the brain and performance is improved. I don’t know if it’s true or not but this is what they were claiming.
I’ve read articles suggesting the same thing. A little bit of sugar tells the brain that nutrition is available, then the brain lets the muscles go quicker, I suppose that may be part of the central governor theory.
jaretj
This workout looks like something a hs xc coach with limited running experience would come up with. It’s a sort of physiological no-mans land if you’re taking full rest. If you wanna do V02 max type workouts you should be doing 2-3 minutes at 3k pace w/ slightly less or equal recovery time. But doing that kind of v02 max work is like the sprinkles on top of the icing on top of the cake. It accounts for a very small portion of your ability to run a solid 10k and up. For the 5k, it probably needs to only be done 4-6 weeks out from A race. Unless your threshold and aerobic system are well developed (which they won’t be unless you’re pushing 70+ mpw), there’s little benefit to V02 max work - you’ll hit a ceiling very rapidly. I’m not saying you need to run 60-70 mpw, but I am saying up to that point you’re better off adding volume than adding intensity. Prioritize volume, progressions, tempos, and LT intervals w/ minimal rest first.
Never drink for a 10k unless it takes you 90 minutes.
My favorite training plan for 10K distance: the quarters pyramid. It takes 11 weeks, and I’d recommend starting it 12 weeks before your goal race. Got this from a man very wise in the ways of the world.
Begin with your current fitness. If you were to go out and run a competitive 10K tomorrow, how fast would you go? Competitive does not mean race pace. It is a good, honest effort - certainly strenuous, but not completely earth-shattering. For the sake of simplicity, let’s say you can hold 6:00 miles, for a total 10K time ~37:00. Do these workouts on the same day, every week, for 11 weeks, and allow for some added rest on that 12th week leading up to race day.
Week 1: 10 quarters (400m on a track) on a 2:00 send off, hold 6:00 pace, so you should be coming in on 90 sec, getting 30 sec rest
Week 2: 12 quarters on 2:00, hold that same 90 sec pace
Week 3: 14 quarters on 2:00, hold that same 90 sec pace
Week 4: 16 quarters on 2:00, hold that same 90 sec pace
Week 5: 18 quarters on 2:00, hold that same 90 sec pace
Week 6: 20 quarters on 2:00, hold that same 90 sec pace
Week 7: Now it starts getting fun, going back down. Drop two quarters each week, but also drop 2 seconds off your pace. This week do 18 quarters, same 2:00 send off, but come in on 88 sec
Week 8: 16 quarters, 2:00 interval, come in on 86 seconds
Week 9: 14 quarters, 2:00 interval, come in on 84 seconds
Week 10: 12 quarters, 2:00 interval, come in on 82 seconds
Week 11: 10 quarters, 2:00 interval, come in on 80 seconds
Great way to get some fitness! Obviously I don’t know what your splits should be, but using this model, you’ll effectively be running 10 seconds faster/400m than you were when you started. If your 400m pace is close to 2:00 or even slightly over, then modify your send off (i.e. run them on a 2:30 interval) My only caution: don’t come out too fast. The first couple weeks can be deceptively easy, and pave the way to injury if you start off faster than you should.
Race well, good luck!
