105 shifting question
Forgive me if this is the stupidest question ever asked…
Is it normal to always have to “trim” the position of your front derailer depending on which cog you’re on in the back so the chain doesn’t rub on the front shifter? I really find it a pain in the ass as I shift down to bigger gears, I’m also needing to make slight adjustments to the front. Is this possibly just a 105 thing?
(Obviously I’m very new to road-type bikes)
There is a way of adjusting the front and rear ders. Sounds like your front is out of adjustment. If you go on the Shimano web site and dig a bit there is a page that tells you how to do this. It’s not hard if you follow the instructions.
First, make sure you are not trying to use the big chainring (front) and big cog (back) or vise versa. That puts the chain at too extreme of an angle on most 9 and 10 speed systems and yes, you will get the chain to rub against the front deraileur cage.
Did you buy the bike recently from a bike shop? If so, you should be able to take it back for an adjustment. Many shops will add in free tune ups for a year or something like that to add value.
HTH
Brett
