I am just curious how those two correlate for you’all. It seems that I can hold a good technique for a quick 100y and swim that in 65s (surely slow compared to you, ST fish) but in Oly I do 30:20 (no ws). It appears I should be swimming a lot faster in Oly. Endurance issue?
Well, I’m not an expert, but yes, I think you should be racing faster. I can’t do 65 seconds for 100 yards in the pool (I’ve never broken 70). The last olympic distance race I did was 2+ years ago, and I swam that in just over 23 minutes. I could probably do it a couple of minutes faster now.
To me the 100 fly and a 1500m open water swim do not correlate much, there is some though:
Fly requires a large amount of strength, and open water swimming definately requires more strength then pool swimming.
IMO - if you are capable of swimming 1:06 for a 100y fly, I would guess that you could probably do 57ish 100y free - based on that I don’t see any reason why you wouldn’t be capable of doing a 22-23 1500m if you had good conditioning…
O.K. Am I missing something? Between your post and replies, are you talking 100m fly, as in butterfly? And then Oly “Free”? Am I confused(I have had a couple of beers).
I don’t think there is a really good correlation between 100 yard freestyle times and 1500 meters open water. There probably even is not that good a correlation between 100 yard and 1500 meter/1650 yard times in a pool, and open water would add a lot more variables to that.
But, anyone that can swim a 65 second 100 ought to be able to swim a lot faster than 30 minutes for 1500 meters open water, assuming that the course is reaonably accurately measured. There are several possible answers. Here are a few. You may lack swimming endurance. How many yards do you swim in practice and how do you structure your practices. You may just swim really poorly so you can get through 100 yards okay, but then your stroke flaws kill you. You could also need some practice swimming in OW. How fast do you swim longer distances in the pool (500s, 1000s, 1650s)? If you open water times are considerably and consistently slower than your pool times, then you probably need to work on swimming in OW.
As most have said - probably an endurance issue…but I quess it depends on how hard you are swimming an OLY? I swim a 100 all out in 1:15-1:20 and an Oly in ~30:00…but that is at my cruise pace.
How many repeats of 100 can you do at 65? I do approx 26 min on a 1500 in open water and 24 min in the pool, but cannot break 75 secs/100 with just 1 rep! I typically go 1.20 for my repeats. Are you sure you are not doing 2.05s for the 100s?
100 SCY isn’t really a good estimator of 1500m Open water. Try swimming a 200SCY and 500SCY for time and compare those times to your 100SCY. With those three data points you should be able to extrapalote a 1000 or 1500 time.
I can swim an all-out 100y in about 1:02 (that’s from a push). My oly swim pb (1500m) is 22:01 (with a wetsuit). As some have mentioned, I would say that fitness is your limiter…more than your technique.
Here’s a good set that helps to establish your threshold pace, which IMO is a better indicator of your fitness than a single 100 all-out.
start your watch and swim 10 x 100 at the fastest pace you can hold with exactly 20 seconds rest in between. It helps to have someone spot the clock for you so you are precise. Take the total time, subtract 3 minutes and divide by 10. The result is your average 100y pace.
15:00 total time - 3 min = 12:00. 12:00/10 = 1:12/100 pace.
Use that pace as a basis for your 100 intervals…My LT pace is about 1:08 right now, so I do my intervals on 1:25 and try to hold 1:10’s.
