1" steerer tube on new bikes?
i’m looking for a frame to replace my old guru chron’alu frame (circa 2002/03), and since I’ve just recently picked up a bunch of new parts, can’t justify buying an entire bike. Does anyone still make a tri frame with a 1" steerer? I’ve got a set of profile carbon-x’s that I enjoy riding, and really don’t want to have to spend another few hundred dollars on top of the frame cost.
thanks,
Any frame with a 1 1/8 non integrated headset can be shimmed to use a 1’’ headset and fork. The shim goes in, then the headset and it’s completely unnoticeable. I did it for the same reason as you with my Kestrel Talon, I didn’t want to give up my CarbonX.
Without passing judgment on the merits of a 1" steerer, one should not decide on his/her frame based on parts found in the basement or for which he/she has fondness. I liken that to trying to find a future wife that fits in a certain type of pants.
Of course shimming is an option too, but that is kind of like wearing a few extra pairs of long underwear to fit into jeans which are too big. :slight_smile:
Herbert
“but that is kind of like wearing a few extra pairs of long underwear to fit into jeans which are too big. :-)”
well better to small then to big ha ha
you must not be from the north it was 42f this morning
we might need the long underwear soon :wink:
dirt
Though I agree with Herbert that really a set of aerobars is no reason to determine frame choice. To answer your question I believe Javelin and Felt both use 1" steerers.
Titanflex.
I prefered the original version better, where you talked something about getting into your wife’s pants :wink:
fair enough. I was entertaining the idea of a new/slightly used frame (for reasonably cheap), as I just purchased a new road bike last year, and cannot justify the cost of a new tri frame. As well, the one I have currently I love, and is totally functional, but it is slightly too big. I suppose the other option is to retrofit the carbon-x’s for more drop, or just ride it as is…:stuck_out_tongue:
didn’t know about the shim though, thanks sweeney for the info. i’ll have to keep that in mind if i can find something in my price range.
Have you modified the Carbon X bars to get the pads lower? If not, there are several threads on ST explaining how to do it, and that would get you a couple of cm lower on your existing bike. Of course, if the bike’s too big because of tob tube length then that won’t help.
All Felt TT/Tri bikes use 1" steerer tubes with the exception of the ITU T23 and T43.
I think all the older Cervelo alloy framed bikes use 1" steerer tubes.
good to know. my favorite lbs carries felt stuff. now…if i could just get a sweet discount, i might be set.
if only the s22 came as a frameset option :stuck_out_tongue:
Only in Europe I’m afraid.
Your options will expand in the USA shortly however.
Regards,
-SD
how about canada? :wink:
actually, what i need to do is get the cash to just afford a new DA frame (or is the b2 the cheaper one?)…that said, the complete bike price isn’t much more than a new frame…so maybe i should just wait a year until i finally have an income and buy a new bike!
they do look fast!
cheers,
-kevin
Sounds like a good plan to me!
an option
http://www.habcycles.com/tt-tri.html
do you mean that having the qualification that my future wife needs to be able to fit into pants that I wear (read: she is smaller than me) isn’t good?
crap…
:slight_smile:
