08' BMC CX02 Frameset (54cm) $799 Free Shipping
08’ 54cm BMC CX02 Frameset (frame/fork/seatpost) $799 Free Shipping Conti US - e-mail gutti82@gmail.com for pics - frameset used for 3 test rides and retails for $1250
**FREE SHIPPING - ** BMC Cross Machine CX02 Cyclocross Frameset 2008, 54cm White Camo Into the Mud
Made for fighting it out in the mud, not the museum. The Cross Machine has been specially developed from the Team Machine and Road Racer and benefits directly from our expertise in making racing bikes with outstanding handling. This year in typical Swiss livery. Easton custom ultralite aluminum tubeset - Easton is the leading manufacturer of tubes for the cycling industry. Skeleton Crosslock Concept (SCC) - Allows much more rigid joints, shorter tubes and longer, and therefore more stable welded joints because of the slanted cutting surfaces. Easton EA50 Seatpost and headset with integrated cable hanger included Fork Details: Steerer Tube: 1-1/8" Threadless Brake Type: Linear Pull - Canti Crown Race: 30.0 Wheel Size: 700c Wheel Mount Center Offset: 0 mm Front Hub Spacing: 100 mm Front Axle Type: 9x1 Material: Carbon/Aluminum Weight: 750.0 g Frame Details: Frame Size: 54.0 cm Color: White Camo Seatpost Diameter: 31.6 mm Headset Type: Integrated, 41.0mm OD bearing 36/36 Front Derailleur Style: Traditonal Front Derailleur Clamp: 35.0mm (1-3/8") Front Derailleur Cable Pull: Bottom Brake Type: Linear Pull - Canti BB Shell Width: 68 BB Thread Type: English Rear Axle Type: 10x1 Wheel Size: 700c Wheel Mount Center Offset: 0 mm Rear Hub Spacing: 130 mm Material: Aluminum Weight: 1,550.0 g
