I have a zipp 404 (front) and 808 (rear) firecrest carbon clincher wheelset (2017). I need spare tubes for both wheels for races, and am looking for the quickest, easiest most dependable spare tube options. I would ideally like to have one-piece valves for both wheels, so I can avoid piecing together a valve stem. I know there is a one-piece valve for the 404 tube (I have one) but is there a one piece valve for the 808? If so, what is the correct size? I would ideally like zipp components if possible.
If not, what size valve extender should I get for the 808? It seems to make sense to carry two tubes with one-piece 404 valves, put an extender on one, and keep a spare extender with me. That way with my two tubes I would have the capability to change up to two flats on either wheel.
What is the best solution? I really don't want to be on the side of the road covered with grease, piecing together an extender, losing valuable race time...
Also, what is a removable core valve? How does it work, how is it different from other extenders, and how/why is it a better valve extender option?
This is probably not rocket science and I am sure this topic has come up before. I don't understand why Zipp doesn't make tubes with one piece valves for the 808 - that would seem to be the easiest, most hassle-free option.
Note- I already contacted zipp but wanted to also post here in the event there are other non-zipp options.
