yet another comment my fit --> Updated
please shoot ;-)
-- edit
unable to add a mp4 to the post so only a jpg.
Follow my project on Project 100 miles / 4 hours
Re: yet another comment my fit [rbe] [ In reply to ]
Raised the saddle 1 cm
Saddle forward 1 cm
Armpads forward 3 cm
Think your bike might be a size smaller than I'd prefer.
Trent Nix
Owned and operated Tri Shop
F.I.S.T. Advanced Certified Fitter | Retul Master Certified Fitter (back when those were things)
i would like to see you riding in that video for a longer period of time, at race cadence, and at race effort. however, based only on what i see, i have 2 comments:
1. you may or may not be 100 percent of the way there, but if not you're 90 percent of the way there. good position.
2. there seems to be a lot of flies buzzing around your head.
Dan Empfield
aka Slowman
What distance are u racing? Can u hold the position? How does your low back feel after that duration?
Re: yet another comment my fit [Fishbum] [ In reply to ]
Mostly short TT's between 15 and 40k.
Did a 100k ride and the back doesn't hurt.
This position is more comfort then fast I think.
it looks fast to me. comfortable can be the most important component of fast.
Dan Empfield
aka Slowman
Re: yet another comment my fit [trentnix] [ In reply to ]
I’m in agreement. This bike looks one size small.
Saddle forward 1 cm
Re: yet another comment my fit [mwanner13] [ In reply to ]
I had to choose size 56 or 58. Both would fit said Felt and my lbs. So I choose the smaller one.
this was my position on my old bike, if i lower the stack 3cm i got the same height as on my old bike.
It looks that on the Argon18 my head is much lower then on my current bike.
i have changed the saddle height 1cm as recommend. that did drop the head a bit. ( have a static photo, no rollers at home that has a thru axle adapter so i dont now if it has any value)
Changes:
saddle 1cm higer
saddle 1cm to the front
arm rest +- 3cm to the front
new extensions
Saddle is a bit too high. Drop it 5 mm (and maybe the cockpit too) and bring it forward another 5 mm. You’re closer.
Trent Nix
Trent,
I'm curious. Would you make the same recommendations if his main focus was doing IMs?
Re: yet another comment my fit [dcon] [ In reply to ]
Frankly, I didn’t even read to know what his goals are. Not saying that doesn’t matter, just that it doesn’t change my recommendations much.
Trent Nix
Thanks.
Changed it again.
Saddle 0.5cm lower, cockpit -5mm and reach +5mm
this is much better. You're in the box.
rbe wrote:
Changed it again.
Re: yet another comment my fit [ericMPro] [ In reply to ]
Thanks for your advice.
Amateur question for you, trent, etc: would you learn more from seeing the rider at a normal cadence and power output? Looks like he's only just getting rolling...
Also general complaints (whinges): make sure camera is level and in landscape not portrait!
(that said, it looks pretty good to me too)
Re: yet another comment my fit [MattyK] [ In reply to ]
Not an amateur question at all.
And the answer is sometimes, yes. When people get going and ride with power they often change where they sit on the saddle. And sometimes fit changes need to be made to accommodate that movement. Others might even change where they sit on the saddle only when they are outside (seen it a few times but it's not that common, from what I've seen) versus on the trainer.
But most of the time, anatomical saddles will encourage a rider to stay put because it hurts in every position except the one the rider likes. So a quick look like those offered in this thread can be pretty informative.
One other note - occasionally I'll see a rider that, over a longer period of time (months or even years) has changed where they like to sit. And that means the fit needs to change to accommodate. It's why it's a good idea to get refit every now and then.
Trent Nix
Should i lower the front, (position is comfortable) ?
Nope. I'd leave it as it is. Looks good.
Trent Nix
Replaced the arm rest with a more comfortable one from the wattshop
Your hands look really high, compared to how I ride. Do your extensions go lower? Looks like they are curved upwards by design. I can hit turns pretty nicely in my drops - compared to other triathletes I see on the course. I suspect this would be tougher if my hands were high like yours are.
Re: yet another comment my fit [Amateur] [ In reply to ]
They are indeed curved, Drag2zero arm rests. The high hands position is a bit more relaxed then the normal position. I am not riding uci races so I can use this position
