dboatx wrote:
im interested in purchasing a tacx neo 2t but watching to shane miller and dcrainmaker i think they mentioned that the trainer may have some problems on some TT frames.
I wonder if somebody out there with Tacx neo 2t and Cervelo P5X combo. Thanks
I am on a Tacx neo OG gen 2 (the re-designed case of the first Neo). Clearance is not an issue and although the Neo 2/2T are redesigns of the internals, from my understanding the externals are identical (the Neo 1 first revision had a fatter case, TT bikes could NOT fit on it well)
Note that there is an adapter for mine that pushes the thru axle adapter out slightly so the disc brake calipers to not rub the case. I believe the new Neo 2/2T can accommodate native thru axles, so this is a non issue, but that I cannot confirm. Do a quick check, but as for dimensions, a Medium P5x fits my Neo 1 Gen 2 fine no issues
