Post deleted by hideano
Re: show me your DIMOND [IronSnowman]
If you go with a bag that has a rounded front it actually captures the air and sweeps it over the top. Check out the Stealth Pocket 400. We tested this bag with ERO Sports on a bike that had a slammed/integrated stem, and there was actually a savings of having the bag on there vs not having one.
Candice Turner
CEO
XLAB - Aerodynamic Triathlon Accessories
Dawn to Dusk - Off-road Specific Storage Accessories
http://www.XLAB-USA.com http://www.dawntodusk.bike
Candice Turner
CEO
Re: show me your DIMOND [Candice - XLAB]
Thanks Candice.
I did have the 500 on my list as the one I'd use if I go that route. I'm a sucker for a clean top tube though. I was looking at the 400i that I have mounted on the back of my saddle and I do believe that I have enough room to fit 2 bonk breakers in there, but I need to come up with a way to allow me to remove just one at a time. Time to hit the drawing board and see what I can come up with.
Can you wedge them & strap them down just underneath the Torpedo bottle between the bottle & the Torpedo mount? I have seen gels up there so can't see why you couldn't do the same with bars. Then you don't have to reach back to get a bar.
Candice Turner
CEO
Candice Turner
CEO
I'm still waiting on the frame, but the rest of the Di2 goodies should be here Wednesday. So I thought I'd get a start with what I have on hand. Just one e-tube wire fished through the bars ready to be cut and spliced into the shifters to keep everything clean and hidden.
IronSnowman: Feb 23, 15 6:59
Re: show me your DIMOND [EricLimkemann]
My new girl is finally dressed and ready to dance!
Also, the Dimond boys are in a close contest! Take a second and vote! Once/day allowed.
http://www.dreambiggrowhere.com/...ails.aspx?entry=1174
machines don't win races, muscles do.
EricLimkemann wrote:
My new girl is finally dressed and ready to dance!Wow.
Is that a new fairing between the stem and frame?
so much wow
Great build! Some more photos details of your bars and cable routing would be helpful.
x2 on the cable entry cover question. Is that an Alden part? Very clean with the fork steerer and Vuka tucked down tight above the headtube:)
Re: show me your DIMOND [chaparral]
Yep, it's an Alden part. He sent over a 3d printed fairing that I'm having painted to blend in a bit more with the frame.
He also did my BTA mount. Awesome stuff!
http://www.alden-designs.com
Re: show me your DIMOND [SummitAK]
I'll get a few close up pics to share. Yes it's pretty clean with the battery and junction box tucked into the top beam.
Only thing better would be a new front end from Dimond... we can only hope!
My new girl is finally dressed and ready to dance! Also, the Dimond boys are in a close contest! Take a second and vote! Once/day allowed.http://www.dreambiggrowhere.com/...ails.aspx?entry=1174[/quote[/url]]
Now that is a sexy bike
"Strive for perfection and achieve excellence"
http://www.trihardercoaching.com
info@trihardercoaching.com
Receive 20% off at trisports.com
Receive 50% off at Rudy Project
Eric, What width Alden BTA mount did you get with the Zipp Vuka Stealth? The standard or the wide version? I have my Vuka Stealth on the way but don't have a width measurement on the extensions yet. Thanks.
Yep, it's an Alden part. He sent over a 3d printed fairing that I'm having painted to blend in a bit more with the frame. He also did my BTA mount. Awesome stuff!
I'm impressed. The Glen Alden part makes a very visible difference over the standard beam. Nice work.
Re: show me your DIMOND [Herbie Hancock]
It's the standard width. Pretty adjustable and has been solid for 3 years of consistent use. The garmin hides nicely behind the bottle, but may be a bit too far back for those riding very forward.
Here is a close up of the cables coming off of the bars into the beam. Pretty easy if you have the right mechanic working for you.
The fairing is in the shop being painted but will sit right on top of everything. I've drilled out a hole for the brake cable to pass through.
With the flash, you can really see how the paint job will look when the sun hits it...
Thanks Eric! Looks nice. The cover will be a bonus. Short stem on the Vuka Stealth? The photo is a little left for stack details. Those are the 25mm risers on the base bar?
Yes, sorry. 25mm risers with a slammed stem. I've actually dropped from 50mm risers and a few spacers on the Shiv a few years ago to only the 25mm risers on the relatively lower Dimond. I've been working with Dave Luscan quite a bit on my fit and have slowly evolved it to a much slipperier position. The move from 175mm cranks to 170 and now 165 mm has made most of the difference. It's taken 3 years of gradual changes and I'm still not sure I'm done, but I've been careful not to lose any power in the process. The bike is important, but position is king.
Re: show me your DIMOND [Rappstar]
Jordan,
Where did you put waterbottle bosses on your bike? I'm thinking I want them on the top tube for a bento box and down tube for an extra water bottle for training.
Herbie Hancock: Mar 7, 15 6:42
Jordan, you've gone on about how the Dimond allows for modular enhancements. Will the new, teased superfork be plug and play with the current frames?
Support cancer research with the world's longest annual charity bike ride.
Texas 4000 for Cancer
Austin, TX to Anchorage, Alaska
http://texas4000.org/
Re: show me your DIMOND [santino314]
Yes, according to the guys from DIMOND the new fork is intended to be used with the current frame
Herbie Hancock wrote:
Jordan, Where did you put waterbottle bosses on your bike? I'm thinking I want them on the top tube for a bento box and down tube for an extra water bottle for training.
Downtube and top tube. I am not sure which - if any - I will use. But it made no sense to me not to have the option.
Yes. Those statements were made in advance of the new fork being announced publicly, but with knowledge that a new fork was indeed coming and that it would be compatible with the existing frame.
Here it is. Well not yet anyway. Chris sent me a handwritten card in the mail and I wanted to share it as I'm rather impressed that anyone would take the time to do this.
