J.Thompson wrote:
Marty
Happy to help if and when you do get something. It will be a case by case basis.
No matter what, you will be replacing the belt and deck. This is not an optional replacement, If you replace one you replace the other.
Anything else you replace will be a case by case basis, and determined once you get the unit and check it out, and tear into it.
It can really be a can of worms if you are looking to go into cosmetics and start powder coating stuff.
The good news, if you are handy, nothing is hard and YouTube can be your friend.
OK, thank you. Right now I am trying to find out some regular maintenance rules besides of cleaning and vacuum the dust in TM. I thought it could be good to oil some moving parts in the engine (e.g. bearings?), maybe the drive belt also... or is it really enough to just get rid of the dust on regular basis?
When I have the unit I let you know how bad it looks like inside :D.
Edit: I tried to contact the local service company and I think I can do the most work myself. I have asked what they do when they refurbish the TM and most of the stuff was the same as you recommended. Only things I didn't understand was "refurbishing the engine" (they did not tell me specifics so I don't know what exactly they can do with it) and also the proposed changing the bearings. Are there any other bearings in TM other than the ones near the engine (e.g. roller's bearings)?
Edit2: OK if the bearings are sealed that would be maybe only thing I could not repair. But if I understand correctly it should not require replacement.
