hi, i have a 2 parts question
just received my vision metron TFA bars. trying to self-dial in right now. it's setup at the max 16 degree tilt as i wanted to have a more praying mantis like support. my elbows are at the edge of the elbow pads, but my hands are resting just slightly below the shifters. should i adjust so my hands are wrapping the shifters?
also, do you cut your extension bars so it doesn't stick out crazy long or leave as is? the cable routing goes into the frame from the sides, rather than from the top of top tube. so i'm wonder even if i don't cut the extension bar, i'll still be left with a big curve cable housing on the outside.
thanks.
thanks.
