In Reply To:
In Reply To:
No problem at all! LOL. As I said, I look forward to seeing your solution. Lots of mathematicians hang out here. I would accept their solution to this problem also.
BTW, part of the reason you haven't seen a "mathematical solution" demonstrated for you is that the mathematics involved aren't exactly basic and involve an Euler-Lagrange framework and a numerical solver, as outlined in this paper:
http://www.itk.ntnu.no/...ications/Ids2002.pdf Take a close look at equation 21 and the paragraph just after it...
"Here we have also included the inertia of the trike, Mcycle. This term requires further explanation:
Mcycle should include the summed inertia of the crank, the chain and the rotating wheels. If the
cycle is stationary and mounted on a trainer, then it should additionally include the effective inertia
of the trainers. If the cycle is moving, on the other hand, then it should instead include the inertia
resulting from the total mass of the rider/trike-system. The individual inertias must of course be
transformed to the crank."
Does he not believe the inertia of the leg components count for anything?
Anyhow, I have already surrendered on my ability to solve this problem mathematically but I see one serious deficiency in his analysis. He looks at the kinetic energy of the thigh and kinetic energy of the cycle without regard to how they are connected and assumes that magically the kinetic energy can be transferred without loss. For this to occur without minimal loss the natural forces on the pedal from a flacid leg would have to be close to tangential to the pedal circle. There is zero evidence that this is the case that I know of. Therefore, any such assumptions are pure conjecture.
Frank,
An original Ironman and the Inventor of PowerCranks
