cable stuck inside STI brifter?
hi everyone -
i'm trying to make a trainer build and am stalled on the right (rear) brifter. it's old (~2008?) ultegra 10-speed.
i got everything cleaned, installed, popped on new cables and housing, and installed the chain today. but then realized that the rear derailleur wasn't shifting at all. the brifter clicks when you press it, but no change in cable tension at all.
a closer look (with headlamp!) reveals that the shift cable head (the little ball on the end) isn't sitting in the garage that it needs to in order to get the ratchet effect. instead it's on the far side of that. it's on the 'inside' (stem side) of the brifter body, up against the port when the cable exits and the housing snugs in.
i have no idea how this happened.
i also have no idea how to get the cable out and fix it.
thoughts?
-mike
https://lshtm.academia.edu/MikeCallaghan
http://howtobeswiss.blogspot.ch/
Re: cable stuck inside STI brifter? [iron_mike] [ In reply to ]
how stuck? can you push the cable and get it out that way?
worst comes to worst, you can always loosen off the lever assembly from the body, but that can be a real pain to reassemble.
of course, the correct answer is that you tell your wife that it's broken and you need Red Etap AXS to replace it....
Swimming Workout of the Day:
Favourite Swim Sets:
Re: cable stuck inside STI brifter? [JasoninHalifax] [ In reply to ]
yeah, pushing it is no good because the ball head on the end of the cable prevents it being pushed through to the correct side, or pulled out the port.
i'd assume that somehow breaking down and rebuilding the thing, in-situ, is the solution, but cripes. . .
the whole idea was this was a cheap build - got a brand-x frame, a free ultegra group, and a handful of cheap bits and pieces. spending $120 on a new 10-speed lever would almost be as much as the frame and fork!
I was just looking at my lever (DA 9 speed), i think your lever is the same basic design with the external shift cable, right?
If the ball is where I think it is, you might be forked. simply removing the lever body isn't gonna cut it, you'll be partially (at least) disassembling the shifting mechanism. at least the disassembly is the easy part....
I've had similar happen to me (not sure the extent of yours). I managed to get the head free using the straightened ends of paper clips to push/release the stuck cable head. It might also be possible to use some fine-tipped tweezers.
....good luck!
an older sti with external cable routing? (cable exits out the side of the shifter, not underneath the bar tape)
I've had to dig some out in the past, a few sheared off ones that were frayed... real pita.
Some (hazy on older shimano stuff) brifters have an access screw on the bottom underneath the rubber grip. Worth looking for it first.
If it doesn't have that, you need to shift to the open position (don't worry about cable tension, just want a straight shot out) tape the lever down to the drop bar (free's up a hand) and start digging around with some hooks/picks (dentist picks work, but you can often fashion something out of an old spoke or such)
My Blog - http://leegoocrap.blogspot.com
I guess it's also hard to get a useful photo of how it's sitting?
Presumably it's not as easy as grabbing the cable head with a good pair of tweezers
If it's 10 speed is it the type with the gear cable exposed running inwards out of the shifter? If so, in the absence of a better idea, do you think if you cut the cable and housing close to the leaver being able to push through that port might help get it out?
Cut it close enough and you might have enough slack to reuse that housing.
ETA you had lots of replys since the one I replied to. This is prob irrelevant now. Good luck
Dental probes and a lot of patience/profanity.
I had to remove one of these on Sunday myself... Reminded me why I like DI2 so much.
thoughts?
-mike
I took a combination of bolt cutters and cable snips to the side of my shifter where the ball cable end thing was supposed to come out. Cut a bunch of plastic away and totally ruined the cosmetic of the interior of the shifter. When I was done with it, it looked like it had been chewed up by a dog. But I got the cable out and back in the right place and it worked fine. I couldn't feel any difference under my hand while riding because the hood smoothed it all out nicely.
I think there may be other better methods that don't destroy things as much. :)
Dr. Alex Harrison | Founder & CEO | Sport Physiology & Performance PhD
📱 Check out our app → Saturday: Pro Fuel & Hydration, a performance nutrition coach in your pocket.
Join us on YouTube → Saturday Morning | Ride & Run Faster and our growing Saturday User Hub
Re: cable stuck inside STI brifter? [DrAlexHarrison] [ In reply to ]
i've thought about it - hopefully it doesn't come to that, though . . .
If they are the 6600 shifters, there is a removable cap that may help you. Part #13 is removable
si.shimano.com/api/publish/storage/pdf/en/ev/ST-6603/EV-ST-6603-2369A.pdf
If they are the 6700 shifter, here is the diagram. Part #9
si.shimano.com/api/publish/storage/pdf/en/ev/ST-6700/EV-ST-6700-2936B.pdf
triumph!
i removed one of the side pieces (thanks, jaret) and fashioned a hook out of a bobby pin (thanks, fredly), and with patience, profanity, and a headlamp, i got it out.
i've reinstalled it properly and it shifts fine; i think soon enough i'll want to replace, though, because i put some real stress on the nipple and i really don't want it to break off in there!
thanks, everyone.
Great!!! Happy to have helped :)
Re: cable stuck inside STI brifter? [fredly] [ In reply to ]
I was going to say this. Also, stepping away from it for a while if you're not getting it out, so you can come back fresh for another try.
http://www.jt10000.com/
Re: cable stuck inside STI brifter? [jt10000] [ In reply to ]
yep - two days ago i nearly threw the entire thing out the window. but i came back to it fresh today and got it cleared up fairly quickly.
it's frustrating because this has been one of those "easy" builds that has taken months: covid, two little kids at home, all sorts of delayed shipments and missing parts, etc.
but today i jumped on, did a 5-minute spin and a calibration, and . . . things seem to be working!
(right in time for the nice weather to come. . .)
Excellent! Glad you got it worked out.
FWIW, my experience has been that shifters rarely see much in the way of ill consequences from this, and when something does get messed up it's usually pretty immediately apparent.
