kyzyl2 wrote:
kyzyl2 = John Hamann. I won't repeat that boring disclosure again on this thread :-)
Most certainly we have not tested every both-leg power meter brand on the market, but for those we
have tried (5 different brands so far), we are confident these do well:
1) PowerTap, any model/configuration
2) Quarq
SRM is not on our list, not because it isn't a great PM (it is), but because SRM's very different method of zero-calibration is something that AeroPod can't handle right now with 100% confidence.
We do not recommend one-leg power meters for CdA measurement. AeroPod measures the total opposing forces of both legs, and when measuring small differences in CdA, you need the DFPM reporting accurately the applied forces of both legs.
We want as many DFPMs as possible to work with AeroPod, so as we qualify more we will add them to the list.
I'll echo your thoughts about some meters being better than others for this sort of application, although it comes down to expectations.
In my experience the CdA resolution I typically achieve varies by meter. It doesn't make lower resolution meters worthless, just there are limits to the resolution of what one can reliably test for. In general I get better quality aero test data from SRMs than from other meters. So I'd encourage sorting out that zero offset function.
There are some things I don't bother trying to test for with some meters that I might with an SRM.
The meters I've used in testing:
- SRM
- Powertap (G2 and G3 hubs)
- Garmin Vector (dual sided)
- Quarq
- Power2Max
- Verve Infocrank
- Stages (but with sizeable caveats as you mention, it's a reliability/resolution thing)
I'm not going to rate them because in reality you can get a good one one day and have great data, and then another day have one that's just not so as good.
That said, the SRM tests have all yielded excellent quality data.
http://www.cyclecoach.com http://www.aerocoach.com.au
