Slowman wrote:
HTupolev wrote:
Slowman wrote:
you're right. i am. i absolutely am. and that's why i said i'm just not smart enough. because, when i study this, and i read what people write about hysteresis in tires, what i read is that there's a value, measurable in heat, during that process between the tire's deformation and its recovery (the delta between the energy during deformation and the energy of recovery). and that sounds an awful lot like measuring elasticity, that is to say, we note the tendency of an object to resume its normal shape after deformation (elasticity) and then measure the energy loss during that process. this is why you're smart and i'm not, and we rely on the smart people here. because you understand the distinction and i don't.
A good way to think about inner tube hysteresis is friction within the tube material, resisting deformation of the tube, turning some of the energy spent deforming the tube into heat.
A plastic tube might be made out of a material that has similar internal friction as butyl rubber, or perhaps even worse. But if the plastic tube is extremely thin, you might suffer less loss to this friction than with butyl simply because there's so little material being deformed.
if i understand you to be talking about friction between the tube and the inside of the tire, okay, makes sense, but that sounds like a completely separate argument than hysteresis. as i understand it, hysteresis is a measurable value in tubeless tires, no?
how I understand it is when you compress something and there is a delay in return and maybe all of the energy input is not returned, that loss is hysteresis loss? maybe in a tube there is 2 types of loss, frictional at the slip plane between the tube and tire and the tube hysteresis? So maybe a tube with a bit higher hysteresis has a lower frictional loss? Has anyone tried the difference between a dry tube in tire and the same tube with baby powder? Is there a difference?
